Possible bad PSOM or speed sensor??
Did you try this as I posted earlier ????
Also, check that fuse #8 and fuse #16 are seated into the fuse holder (in the cab) snugly. A loose fuse in a fuse holder will cause intermittant power.
Also, IIRC there was a TSB about the screws in the dome light assembly that could be causing your symptoms.
Bob
Bob
I hate to say it, but....I told you the other day it was not the PSOM causing your problem.
I see in your other thread the VSS was bad, a new one fixed the problem.
Happy to see you got your issue resolved.
So you are saying the truck does not have an E4OD 4 speed automatic overdrive transmission? I know of very few trucks with C6s in this vintage. If that is the cause you have a completely different non-electrical related issue. The C6 transmission is 100% mechanical/vacuum controlled.
You should also verify if the transmission has 17 or 20 pan bolts. The C6 has 17. Also take a look at the shape of the pan. Use this for reference:
#29
#30
The C6 transmission is controlled by the vacuum modulator located on the side of the transmission and the linkage/cable attached to the throttle. I am not that familiar with this setup on this vintage truck. I would suggest to start with the basics, i.e. check the fluid level, verify the modulator has vacuum running to it and make sure the linkage is attached.
