1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Exhaust manifold leak V10 ?
Old 09-18-2016, 02:10 AM
I-am-a-fossil's Avatar
I-am-a-fossil
I-am-a-fossil is offline
2003 F350 short bed 6.8L V10---On start up a slight tap sound, almost like a cranky lifter, but it is an exhaust manifold leak. At the bolts, I am not sure. This has been this way for 5 years, no better no worse.
After I run about 2 to 3 minutes it seals itself. Not a hint of noise. Due to heat, something is expanding to seal it (aluminum).
At my annual PA. State Safety Inspection the Tech says 'that has to be corrected if it worsens', but It does not fail inspection.
This puzzles me.
How is the call made for correction. A flip of the coin, a guess and is it serious enough to fail inspection. Is this normal with the 6.8L or V10s.
I know the cost involved for a fix is big league, but can it be justified.
TRUCK RUNS GREAT !-----your thoughts
fossil
Old 09-18-2016, 06:25 AM
Mosesmoney2010's Avatar
Mosesmoney2010
Mosesmoney2010 is offline
Crawl under and snug up the two nuts ????
Old 09-18-2016, 09:17 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
The V-10 is pretty well known for this very common exhaust manifold stud failure.
Is this leak at the head/manifold joint or at the manifold/down pipe joint? Take a close look at your exhaust manifold studs (the ones that go through the manifolds into the heads), there should be 20 of them in total, I'll bet that you are missing a few.
PA can fail a vehicles on safety inspection for any exhaust leak, since it is closing up with engine heat quickly the tech is turning a blind eye to it, but like he told you, if it gets worse it will not pass inspection.
The shop quotes I've seen mentioned around here seem to run from $400 to $800 to remove the manifolds and replace all the exhaust studs with new. I had 2 broken and missing studs on my V-10. I took advantage of that issue and my desire for improved performance and removed my manifolds and studs and replaced with a set of Banks headers and new bolts. I did the job at home and removed the 2 broken studs without too much drama, welded a nut to 1 and it spun out fine, the other I had to drill and use an Easy-Out on. The other 18 non broken studs came easily with a hammered on socket and ratchet.
Old 09-18-2016, 10:21 AM
ashleyroachclip's Avatar
ashleyroachclip
ashleyroachclip is offline
If you are reasonably skilled with hand tools, you can use a reverse twist drill bit , to remove the broken studs , and install new.
I have done this exact thing, only replacing the broken .
Have had no more break , and has been good for 3 almost 4 years.
Old 09-18-2016, 11:19 AM
44dwarf's Avatar
44dwarf
44dwarf is offline
If you go over to the V10 forum there is plenty of info on how to do this repair right and many examples of doing it wroung as well. Take your time with proper preperation you can do it.
Tbanks1382
10-02-2016 09:02 PM
brent penfold
Exhaust Systems
08-12-2015 04:46 PM
jstanley
12-05-2009 11:23 AM
Jim59
22
11-13-2007 02:19 PM
TNHILLJACK
01-19-2007 02:34 PM
Quick Reply: Exhaust manifold leak V10 ?
