im planning to weld a roof rack on my own so im thinking about the maximum load the roof of my 97' eco could handle?
the rack it self has a planned weight of 54kg, so i guess its a little heavy
On my old E-350, I installed 4 heavy duty cross bar racks. Each one was positioned directly above the wall studs ( or body ribs) and had 8" triangular gussets distribute weight in the rain gutters. Used all Grade 8 hardware. We needed a-lot of 1 1/2" steel pipe on a jobsite and nobody could deliver it until the next week. I had them set about 1800 lbs. of pipe on the rack with the fork lift. So maybe @ a ton, including the rack. No problem at all for the body but the handling scores a perfect 10 on the pucker scale! Cheers!
I had a roof rack on my last van with 3/4" ply on it
we lifted 500-600 lbs. motorcycles on the roof to do burn outs on it
never had an issues with the van
In the Installation Instructions they worn about not to exceed GVWR, locate load as low as possible and center it, danger of roll-over and such; but 1700# is impressive nevertheless. The rack itself is about 200 lb, and removal/ install is a chore.
