clutch/brake pedal questions
Old 08-11-2016, 06:00 PM
lance65's Avatar
lance65
lance65 is offline
Are there any differences in the pedal assemblies(pedals and boxes) between bricknose trucks? I just bought a hydroboost and pedals from an 88 F-SuperDooty that had 7.3/ZF5...will the assemly bolt into my 89 F250 gasser? I am swapping out the C6 for a T18 and adding hydroboost.
Thank You
Old 08-11-2016, 06:18 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Thank You
The pedal boxes are the same, but you do need to use the F-superduty brake pedal. The push pin is located in a different spot for a hydroboost
Old 08-11-2016, 06:24 PM
lance65's Avatar
lance65
lance65 is offline
I have the pedal from the SuperDooty that I got the hydroboost from. But also cant I just raise the pin 3/4"? I am about to do hydroboost on my 84 F250 with a 6.9/T19. So on that one, I was just going to raise the pin 3/4"..I read a thread on OB and Riotwarrior explained that was the only difference and those were the measurements.
Old 08-11-2016, 06:25 PM
lance65's Avatar
lance65
lance65 is offline
BTW, Thank You
Old 08-11-2016, 07:58 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
E4TZ-2455-B .. M/T Brake Pedal with Power Brakes / Obsolete
1984/91 F150/350, F(Super Duty) & Bronco.
E7TZ-7519-A .. Clutch Pedal / Obsolete
1987/91 F150/350, F(Super Duty) & Bronco.
J Scott
05-11-2018 06:16 AM
cliffordingles
07-14-2016 11:29 PM
mcdimen
08-24-2014 11:16 AM
SonofaFord
09-30-2011 06:51 PM
Quick Reply: clutch/brake pedal questions
