Speedometer wrong speed
Old Jul 10, 2016 | 09:03 PM
Phil Fleming's Avatar
Phil Fleming
The PO of my 79 F150 converted the truck from a 351 automatic to a 300 4spd manual (T18). Today I was checking my speed against my wife's car and the speedo is displaying low about 20km/hr. My speed shows 60 km/hr (37mph) actual is 80 km/hr (50mph). Any thoughts on how to correct this?
Old Jul 10, 2016 | 10:18 PM
1320stang's Avatar
1320stang
Change the tire height or the speedo gear on the end of the cable where it enters the trans.
Old Jul 11, 2016 | 01:46 AM
Phil Fleming
The tires are OEM size, are there different speedo gears based on transmission type? Does anyone know the required gear for the T18 4spd transmission? The truck is 2WD.
Old Jul 11, 2016 | 07:30 PM
palmrose2's Avatar
palmrose2
37x2=74 50x2=100 Your speedometer is reading 74% true. What you need is a speedometer gear that spins the speedometer 36% faster. You can do this by using a speedometer gear that has 36% less teeth.
Let's say your gear has 21 teeth. You would need to replace it with a 16 tooth gear. 21/16=.762 or 76% Close enough.
I would use GPS to check my speedometer. Who knows if your wife's car is perfect?
I think that the T18 and C6 speedo gears are radically different. I would pull the cable from the trans and see what I'm dealing with and compare to available gears.
M WinWy
Jul 6, 2019 06:32 AM
Brian Young II
Feb 17, 2016 10:21 AM
strokerfe
Jul 2, 2011 08:27 PM
peterbilttrucker
27
May 3, 2009 02:01 PM
MintFord
Oct 14, 2007 12:23 PM
