steering toyota coversion f100
Old 05-28-2016, 03:42 AM
capelo's Avatar
capelo
capelo is offline
Originally Posted by 1oldtimer
I have a floor shifter from a Granada in my '54 panel, but it uses the stock steering column.
https://www.ford-trucks.com/forums/9...mn-repair.html
Thanks for the link. a job well done looks. but I want to keep the three speeds on the tree. at the end I use to center the bar down?
Old 05-28-2016, 03:46 AM
capelo's Avatar
capelo
capelo is offline
Originally Posted by turnrjr
I see in your gallery entire contraction process is very interesting. 👍
Old 05-28-2016, 08:22 AM
capelo's Avatar
capelo
capelo is offline
I've located the coupling
Old 05-28-2016, 08:46 AM
capelo's Avatar
capelo
capelo is offline
My engine is a and block 292. that advise pump
Old 06-13-2016, 04:58 PM
capelo's Avatar
capelo
capelo is offline
Hello I need your help selecting a steering pump that best suits me 292. thanks
Old 06-13-2016, 05:30 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Are you installing a Toyota power steering gear?
I can't see if you have 2 grooves on your front crank pulley. You'll need two. You can buy a add on pulley.
After that you can buy an original power steering pump or a saginaw pump and bracket, also called a canned ham pump (it looks like a canned ham). The Saginaw with bracket is easier to find and probably cheaper. The pumps are sold in the US with out a front pulley so be sure to make sure you have that as well.
Old 06-14-2016, 12:49 AM
capelo's Avatar
capelo
capelo is offline
Thanks for the reply. I have only one slot in the pulley. I could put a picture of what you need or reference to search and buy?
Old 06-14-2016, 07:26 AM
bjmayberry2
Here are pictures and a source for original ford power steering brackets & pulley. HOME PAGE********************** Y
Here's a Saginaw kit on eBay. https://www.ebay.com/itm/252391095685
Saginaw Pump & bracket.
Old 06-15-2016, 08:58 AM
capelo's Avatar
capelo
capelo is offline
Thank you very much for the images and the link. this support keeps the fuel pump on your site?
Old 06-15-2016, 09:09 AM
bjmayberry2
Yes the fuel pump is in it's orginal position it's behind the power steering pump.
Power steering Pump installed on Y Block
Old 06-15-2016, 04:34 PM
capelo's Avatar
capelo
capelo is offline
thanks for the clarification. a question, that type of pump riding any vehicle originally?
Old 06-16-2016, 03:50 PM
capelo's Avatar
capelo
capelo is offline
This steering pump got it second hand in a workshop. I believe that it can serve?
  #28
Old 06-16-2016, 03:59 PM
bjmayberry2
You may end up installing spacers between the pump and the Bracket to get it to align with the crank pulley but that looks like it will work. In looking at the picture that reservoir looks pretty beat up. Maybe it'd just the picture but male sure the pump turns freely and it doesn't leak. Have you got your power steering mount and did you find a add on crank pulley to get the 2nd groove?
  #29
Old 06-16-2016, 04:10 PM
AXracer's Avatar
AXracer
AXracer is offline
Yes that is a Saginaw pump, but it has a long pulley shaft on it. You would need to find a mounting bracket where the pulleys lined up. The Saginaw pump was very popular (cheap/dependable/adjustable pressure) so they were used on most70s and newer (Up until rack and pinion steering became the norm) all General Motors, some Fords and some Chrysler products. If you buy a used box be sure to get the high pressure hose and the fitting that screws into box. it is an unusual size (17mm) and very hard to find (note that low pressure return hose uses a 16mm fitting at the box. The 16mm return fitting will screw into the 17mm port but will leak badly!)
  #30
Old 06-16-2016, 04:39 PM
capelo's Avatar
capelo
capelo is offline
pump looks good and properly .The tour seeking a second slot I have not started yet. I'm thinking about making a link to the original made by a turner. do not know if there are better options
Quick Reply: steering toyota coversion f100
