Sponsored by: Real Truck
Electrical issue please help!!
Old May 20, 2016 | 03:16 AM
twisted064's Avatar
twisted064
This is in my 2006 f350 4dr 8ft bed single axle, 6.0 diesel with sunroof (could be factor).... so this has happened twiçe now, I have lost ALL power after cutting the "truck off" like you would normally. The problem begins at this point, there is no power electrically. I mean no power at all, no ignition, no interior lights, no power to ANYTHING......
THIS IN ITS SELF IS STRANGE ......... BUT ...... The fix is where I'm just at a loss, to fix a complete power outage situation and return to complete normal operation is to simply open and shut the passenger front door.
PLEASE HELP WHEN YOUR DONE LAUGHING ,!! Thanks in advance
Old May 20, 2016 | 04:19 AM
Chuck's First Ford's Avatar
Chuck's First Ford
bad connector at battery.. or battery cables... both positive or negative ... rusted ground connection at body or frame.
bad connection INSIDE of battery (bad battery) had this happen to a motorcycle of mine, 100 miles from home.
the door causes a shock in the truck body..
Old May 20, 2016 | 09:36 AM
Crispy71's Avatar
Crispy71
Agree, go through all you grounds and your main power cables. Have your battery checked
Old May 20, 2016 | 11:08 AM
bobv60's Avatar
bobv60
Another place to look is the retained power accessory circuit in the instrument cluster. Search Circuit Board Medics. The are good people as can help you confirm or eliminate the IC as the problem.
Old Jun 1, 2016 | 02:24 PM
twisted064's Avatar
twisted064
Ok so here's the next phase....
I'm in Va. And it's rained forever here I think!! I've checked the batteries and cleaned the cables and everything is good there. Now yesterday i had the battery light come on, and then went off this morning, I've had no codes pop up, and the batteries are new and show 12-13 volts and the alternator checks out ok. Then I get out of the truck this morning the radio comes on and the dash lights up like its ready to start??? I'm thinking a screwy ground somewhere but not sure.......I hate electrical gremlins!!
Old Jun 1, 2016 | 06:58 PM
projectSHO89's Avatar
projectSHO89
Now you have a completely different problem, likely caused by a leaky windshield allowing water to get into the fuse box.
77f250400
1983 - 2012 Ranger & B-Series
Apr 6, 2012 09:52 AM
swampfire79
Feb 11, 2012 02:40 PM
airmac20
1997 - 2003 F150
Jun 17, 2011 11:04 PM
Ryana
Jan 10, 2010 07:45 AM
runemaster
Sep 7, 2005 07:54 PM
