FE 352 transnission issue
#31
#33
Well I got the answer today. After talking with a couple of people with knowledge of the FE motor, I was informed I would need to change the crank I order to make it work. There isn't a torque conveter that fits this particular motor. I'm throwing in the towel on this motor and getting something different. I was never a fan of Chevys in a ford but I got my eye on a Cadillac 500 that I can get a great deal on. Don't know that I can pass it up.
#35
FE Crank?
Darn, you realize that it would be way cheaper and easier to get the crank you have now drilled than to try and stuff a Cadillac in there. You think you have problems now you will have them 10 fold trying to put Cadillac in there. Can you post a couple of pictures of your engine?
#37
FE crank
Darn, from what I can see in your picture there is nothing wrong with your crank. The picture I'm posting is an early 1971, 429CJ crank. The only FE crank I have is out in a shed buried under other stuff. But the crank flange is identical to an FE. The big hole is the one the converter goes in. The small "1.250" hole is just a left over from the machining process and not used for anything. That big hole in my crank is 1.85 diameter and .450 deep and that's where your converter goes. I think you may have a flexplate problem.
#39
#40
Torque converter
I measured the nipple on the front of the torque converter and its is 1 3/8 the crank is 1 1/4 when I explained this to the transmission shop I bought the T C from they are insisting its right. But it still doesn't fit. When they look it up under 1965 F100 with a 352 they have nothing for it. So they did it as a 1966. This could be my problem. I've tried to ask others but they have nothing on it. Apparently its not easy to find someone who knows about these motors. And getting parts, supper pain.
#43
Torque converter
Darn, It's bottoming out because you have the wrong converter. The 1.375 pilot is 1.61 inches long and the 1.848 pilot is .96 inches long. Get the correct converter and it will go together. Good Luck.
#45
Thanks Crop Duster. Looks like your right. When it was explained to me the first time I thought it was supposed to fit into the smaller hole in the crank. I'm going to exchange my converter. Fingers crossed. I'm still going to get that Cadillac. I have another project for it. A 1947 ford box truck.
