Project Lazarus-The Mare Resurrection
#136
I just mounted mine in the most common location which requires the least amount of core support cutting, but there is plenty of room for me to have moved it lower. Plus mine is a 7.3 IC; aren't the 6.0 ICs taller?
#140
Thanks Nik! I'm hoping to have driveshafts, exhaust, t case, trans, radiator and core support out of red this week. The plan is to bring a machine home from work for the long weekend and pluck the ol 7.3 with a skid steer. This was I'm not worrying about over extending the HF engine hoist and I can do a little grading around the property to boot!
#141
The mare already has holes cut for an intercooler. I have a 7.3 here, I better pressure test it. I guess the homes could be opened up more if need be.
Think they are pretty darn close but the 6.0 is wider by a bit
Because I said this it will likely fold next time, but that cheapo HF 2 ton hoist has pulled a few dozen 12v and 7.3s at full extension without issue, out of a truck bed or frame, granted a trans and t case was never attached :-)
#142
Remind me, does this kit lift the truck? or just change the springs and or position for a better ride?
#143
Right on. the skid should make it a breeze! Thinking of just leaving it all bolted up and moving it as a unit or piece by piece?
The HF hoist that my brother has, I would trust and borrow, but the one I have came second hand and the previous owner left it out in the elements for some time. I don't worry about the steel as much as the hydraulic cylinder failing. Plus I just reaffirmed with the owner of the company that I could bring the skid steer home Friday.
It does lift the truck. They have a couple different options, but I went with the smallest lift possible with the 2.25". I really wanted no lift as that is not what the build purpose of this truck is about, but alas no one sells a no lift RSK. At least not one I could find.
#144
With the skid steer and front pulled, I may do it as a unit. I'll pull the t case at least. We shall see. No work tonight.
#145
At the end of the day, I'm willing to add some lift for a better ride. You know I don't care about fuel economy.
#147
Got some time tonight and started pulling the front end. Man this poor girl is rusty. There's no doubt I'm making the right decision in starting over. Only thing holding the core support are the 2 large bolts underneath and the AC condenser lines which are soaking. Here's a couple pics.
The rot
#149
