The Jord build- crew cab Cummins flat deck
The original bench seats are long gone and the buckets and rear bench that were in this truck got scooped for my mud truck. I wanted shoulder belts all the way around so I ended up trading a couple hours labor for the seats from a early 2000s Super Duty extended cab.
After a bunch of cutting and welding on the mounts here's the fronts
t
I wanted to use the rear from the Super Duty also but it was too wide and the rear door window cranks wouldn't have cleared. So the rear seat was stolen back from the mud truck. Its from a 90s Aerostar van. I fabbed up mounts for the rear shoulder belts from the Super Duty
I'm pretty happy with how the seating turned out. I feel good about having shoulder belts for my family and 4 adults should fit comfortably in the cab
t
That brings us up to date. I finished welding the front seat frames yesterday and painted them.
Next on the list:
-install hood latch, cable etc with release in cab
-install clutch slave cylinder, hydroboost master cylinder, throttle cable in firewall
-start repairing rusted cab corners, front cab mounts, and door corners
-install towing mirrors from newer truck
Other plans:
-paint body(possibly rat rod look)
-undercoat cab and spray liner floor inside
-custom flat deck and front bumper
-turbo upgrade
-homemade exhaust brake
-airbag 3 link rear suspension
-methanol/water injection
-etc....
I'm doing all the work myself and keeping the budget very limited but it's a lot of fun
Next on the list:
Other plans:
-turbo upgrade
-etc....
Thanks for looking! I do agree with the Ford in a Ford thing, and if this was an F100 it would definitely be a Ford engine.
I want to be able to hook up to a 10,000lb trailer and drive thousands if miles if I like. And for that purpose a diesel is the way to go. Few would argue that a 12V Cummins is the easiest and most reliable diesel swap for a pickup.
The bed will be a fully custom flat deck and it will be cool...
#28
I'd rather people just stayed out of this engine bay
#29
#30
Well it's been awhile since I've updated this thread. I've been busy repairing rust for the last month or so. I cut out and replaced both cab corners, the inner panel behind the corners, the front cab mounts and miscellaneous other rust. Here's a few pics
Cab corner before
Cab corner after
Passenger side B pillar before
After
Front cab mount before
Cab mounts after
There were a bunch of other minor repairs to the floor pans etc. Then I sandblasted the underside of the cab
Now I'm ready to prime and undercoat the cab
Cab corner before
Cab corner after
After
Cab mounts after
