Quick wiring question
Old 03-22-2016, 03:05 PM
Jeff53's Avatar
Jeff53
Jeff53 is offline
I've installed power bucket seats in place of the 40/20/40 manual bench seat that was in my 2004 Excursion when I bought it. The driver side was a simple plug and play. For anyone who has gone this route before, did you find a wiring harness for the passenger side under the carpeting? I felt around all over the floor under the passenger side carpet and couldn't find a connector for the passenger seat. Is it possible that it's tucked behind the passenger side kick panel or some other place. I have the sill plate off and it's not in there. I did find a bunch of wires that were running from the passenger side to the driver side under the carpet right behind the seats. The driver's harness was connected to this on the driver's side, but it didn't feel like there was a plug taped up on the passenger side of this run. Anyone ever do this before? If push comes to shove, I can run a wire with a 30 amp fuse off of the battery, but I'd rather use the factory plug if it's there. Thanks.
P7M8
Electrical Systems/Wiring
17
09-26-2012 11:45 AM
splice1985
1999 to 2016 Super Duty
05-14-2010 05:23 PM
bigtimebubba
02-16-2009 09:01 PM
Torsen Rick
Aerostar
07-22-2008 07:46 PM
jinxie
05-20-2008 05:04 PM
Quick Reply: Quick wiring question
