1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Intercooler bushings
Old 03-21-2016, 03:13 PM
Renegade3064's Avatar
Renegade3064
Renegade3064 is offline
Im looking for the two upper intercooler support bushings (also called "grommets"). Apparently they are unavailable from Ford and I cant seem to find them online. Its originally a V10 truck that I put a Cummins into with an intercooler but apparently my used intercooler didn't come with them.
Part #F81Z-6C680-AA
Old 03-23-2016, 02:07 AM
davester250's Avatar
davester250
davester250 is offline
maybe make however many you need out of a tube with the appropriate ID/OD [OD is more important, you can drill it out if ID is too small]? Then cut off with a hacksaw. Should be pretty straightforward to do.
If they are rubber, you can cut of a pretty thick rubber matt [Matt, hold still, this will only hurt for maybe a month or two] in the appropriate shape. If it's too thin, double up on the layers.
Old 03-23-2016, 07:52 AM
Tom's Avatar
Tom
Tom is offline
I can't find much on that part number for interchage, but if you know exactly what it's off of you can probably find one at a junk yard. These trucks are quite common, there isn't much you can't find at a salvage yard for one.
BillM2
12-15-2016 11:21 AM
RV_Tech
Fifth Wheel & Gooseneck RV Towing
07-24-2016 08:21 AM
ludafisk
12-12-2013 06:09 PM
gscottc
08-17-2007 12:11 PM
FordPerf300
04-19-2004 10:42 PM
Quick Reply: Intercooler bushings
