89 302 EFI Missing Problem
Old Aug 11, 2003 | 01:26 PM
wdj's Avatar
wdj
My engine was rebuilt about 2 years/20,000 miles ago. It ran perfectly until a few weeks ago. All of a sudden, it developed an intermittent dead miss that I corrected with new plug wires. After that, the miss was gone, but the truck was still a little sluggish.
About two weeks later, the truck idled and cruised smoothly but started to miss again. Instead of a dead miss though, this miss only occured under acceleration - especially at low RPM's. In some cases, with larger amounts of throttle, it would backfire.
Last week, I replaced the plugs, cap, and rotor. All 8 plugs looked exactly the same with no evidence of any problems. I gave it two bottles of fuel system treatment. The cap had a pretty corroded contact and the rotor was worn so I replaced those.
Although the tune up has it idleing and cruising better, I'm still getting the same misses & backfires under acceleration that it had before last week's work. I don't think that it's a fuel system problem because if gas wasn't getting dumped into the cylinders, then there wouldn't be any be backfiring. Since this only happens when I give it more throttle, I'm suspecting that my timing is not advancing like it should under acceleration.
Since I have replaced all of the cheap & easy tune-up type components, is my next step to check the codes? I found the threads on checking codes, but where's the computer at?
Old Aug 11, 2003 | 02:56 PM
wdj's Avatar
wdj
One additional question: According to one artlce I found, EEC-IV wasn't used till 1991. Do I still follow the same procedures to get codes from my truck?
Old Aug 11, 2003 | 03:26 PM
blu's Avatar
blu
On my 88 302 F250 its located on the driver side above the fender well. Has a cap on it that says EEC Test. (Or something similar)
Old Aug 11, 2003 | 03:27 PM
wdj's Avatar
wdj
blu, did you test it the same way as described on this site? are the codes for yours the same as for EEC-IV?
Old Aug 11, 2003 | 04:01 PM
blu's Avatar
blu
Yep. Test it the same way.
Jumper with a file clip to give the signal to retrieve/send codes and use an analog voltmeter to read them. Its pretty straight forward after doing it once.
Old Feb 26, 2004 | 01:23 PM
Daniel.r's Avatar
Daniel.r
I have an 87 and would like to get the codes for my missing. How exactly do I do it ?
Actally I would just like to know how to get "the codes"
Daniel
p.s.
My truck sat for a year and one half and has all new plugs, wires and everything, I am assuming fuel filter.
Old Mar 1, 2004 | 09:43 PM
ardmech's Avatar
ardmech
I have an identical set of symptoms as originally described by wdj. My vehicle is an 89 F150 with 195,000km on the clock. I have done everything so far described in this thread. Has your fault been resolved yet?
Barry
Old Mar 1, 2004 | 10:29 PM
EPNCSU2006's Avatar
EPNCSU2006
To get codes: go to http://fordfuelinjection.com and click on "Getting Codes" on the left side of the screen.
Old Mar 3, 2004 | 07:40 PM
chris1978's Avatar
chris1978
if you have reas my thread it is almost like mine it turned out to be the EEC relay was bugging out. take out the relay and jump it with a wire drive it (not for a long time ) see if that helps
Old Mar 3, 2004 | 07:42 PM
chris1978's Avatar
chris1978
also check your fuel filter and pressure if its EFI should be around 40psi
Old Mar 3, 2004 | 09:39 PM
ardmech's Avatar
ardmech
Thanks Chris1978
I have had my problem for about 3 years. I sometimes get codes relating to the thermactor and EGR. I replace a few components and the codes go away but the miss remains. I will try your selay suggestion.
Old Mar 17, 2004 | 12:11 AM
ardmech's Avatar
ardmech
I have just changed the plugs, leads, fixed a vacuum leak, cleared all codes, fuel pressure ok, cleaned the idle speed valve, new air filter, etc. Still the same fault exactly as described by WDJ at the beginning of this thread. I can't email him to find out how he went as I am a new user. Does anybody know?
Barry
Old Mar 17, 2004 | 12:43 AM
c96drumm's Avatar
c96drumm
Click on the "Profile" link on the bottom line of his last post on this thread. You'll see an email link there.
Old Apr 13, 2004 | 01:06 AM
ardmech's Avatar
ardmech
F150 1989 with a miss at low rpm
I would like to contact wdj as the symptoms of his problem sound identical to mine. As I haven't yet placed 15 posts I cannot email him. Can anyone help please.
Old Apr 13, 2004 | 06:48 AM
Lagerlot's Avatar
Lagerlot
I have a 90 302 efi that is acting similar. it idles fine when its in gear it shakes,, enough to take notice and wonder what the heck is wrong now ,, but under full acceleration no miss. it shimmies at when i'm not hard on the gas. I'm guessing new wires roter and cap and quite possible a new coil. seems like it gets enough spark when the rpms are higher. I did put new plugs in it . 1500 miles ago
