King Pins
Old 02-28-2016, 02:57 PM
kdaug5's Avatar
kdaug5
kdaug5 is offline
King Pins
Here I go with my next problem. I went to get an alignment. When they put my truck on the rack they showed me the play in the king pins. The previous owner told me these were just done and they look to be. I never really checked for play but it's there.
So the alignment guy told me it could be missing shims?
I will do my research through the web but looking for help here too. Are these tough to replace or repair? How should I go about fixing this? Can the average do it yourselfer tackle this at home?
The truck is
1968 F100 2 wheel drive
Someone upgraded to the 73 -79 disc brakes
Thanks
Kenny
Old 02-28-2016, 03:28 PM
treverd's Avatar
treverd
treverd is offline
The previous owner could of used the easier to install "Nylon Bushings" instead of the brass type bushings. I have read stories on this forum of guys feeling play in their front end after 6 months of installing the nylon type bushings.
The nylon type do not require reaming/honing of the bushings that the brass type do.
Hopefully the bushings are in good shape and it will just requires some shims. If it requires new bushings and king pins, most on this forum will tell you that it is much easier for a machine shop to install them correctly.
If you can get the hub assembly taken apart and bring them to a shop to push out the old bushings and ream the new you cold probably get it done reasonably cheap. Maybe ($100 - $200)
I am sure some will chime in on the horror stories of trying to accomplish a king pin job by hand.
Old 02-28-2016, 04:14 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
If the kingpins have been in place for years, they may be very resistant to being driven out. On the other hand, if they were "just done," it shouldn't be difficult to remove the pins --particularly if there's slop in them.
It may be very difficult to find a local alignment shop or garage that has the reamer to install/ream bronze kingpin bushings. You may have better luck checking with a big truck shop or possibly an engine shop for someone that has the equipment and/or knowledge of rebuilding a kingpin front suspension.
'Slop' in the bushings would tend to indicate the bushings are old and worn, nylon or, the bronze bushings were reamed too large on the I.D. to start with.
I borrowed a piloted reamer and an adjustable reamer from a local engine rebuilder and did my own kingpins ('77 F100 front discs on a '69 F100). The kingpins are .859" diameter.
Old 02-28-2016, 08:44 PM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
The answer to your question depends on what type of "play" there is. If the play is only up and down play then more shims need to be added to the kingpins. If there is in and out play, that is to say left and right, then yes you have bushing play. This assumes that the kingpin lockpin is in tightly and the nut is tight.
Old 02-28-2016, 08:46 PM
mrpotatohead
My 67 f-100 had factory nylon bushings and they lasted 93,000 miles and could have gone further.
Old 03-01-2016, 02:44 PM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
Agreed, I replaced kingpins when I installed the disc brakes and they had been in there for years. The bushings were plastic and still in decent shape. Not as good as bronze by any means but should last longer than 6 months.
Old 03-01-2016, 09:37 PM
greasy rider's Avatar
greasy rider
greasy rider is offline
The truck is
Thanks
Kenny
A few weeks ago I needed new front tires and since one of them was much more worn than the other I asked them to do an alignment too. I was told that the kingpins were too bad to do an alignment. So I bought a set and this past weekend a friend and I set out to change them. We found that there was nothing wrong with them. The slop in the wheels was just that bearings needed to tightened. For those keeping score at home, the difference in the cost of a kingpin replacement and just tightening up the front wheel bearings is substantial. Just saying
Old 03-01-2016, 11:52 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
greasy rider---It's odd yet very true that little things like that are overlooked and the fix is easy. Done that a lot myself as I can be a bit forgetful at times.
Old 03-02-2016, 12:21 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Sounds like that guy was finding reasons "not to do an alignment."
Old 03-02-2016, 01:14 PM
DLW-70-F100's Avatar
DLW-70-F100
DLW-70-F100 is offline
ultraranger, what was the size of that reamer you used for the .859 king pin?
This is another project since I did find slop in the passenger side king pin. I'm assuming a .859 reamer would give a .860 cut, but this is new territory for me.
Old 03-02-2016, 01:17 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by treverd
The previous owner could of used the easier to install "Nylon" bushings instead of the brass type bushings.
No such thing as brass bushings, they're BRONZE!
Brass bushings would wear out much quicker than nylon bushings, probably in a NY minute, as brass is a very soft alloy.
Old 03-02-2016, 01:35 PM
treverd's Avatar
treverd
treverd is offline
Thank you for the clarification.
Old 03-02-2016, 04:39 PM
qman's Avatar
qman
qman is offline
Did my king pins and bushing last summer. It was a snap.
Old 03-02-2016, 05:53 PM
mrpotatohead
No, the alignment shop wanted to gouge the guy for some kingpins that it didn't need. A common ploy done by unscrupulous shops.
Old 03-02-2016, 08:38 PM
greasy rider
I was thinking the same, but maybe it was based on the age of the truck.
Quick Reply: King Pins
