1978 - 1996 Big Bronco
Header options
Old Jan 11, 2016 | 11:44 PM
coachnichols's Avatar
coachnichols
Header options
Need some help. I've got a 1994 Bronco with (I believe) the original 5.8 liter V8. My first question is will putting on headers cause any issues with the original system/setup (computer, fuel injection, etc.) that I will need to be prepared for dealing with? Second, is it "worth it", meaning what benefits will the provide? Last, I think I can get a good deal on Flowtech Long Tube headers. Is this a "do it yourself in the driveway" type of job or am I better off paying a professional to do it?
Thanks for the help!
Old Jan 13, 2016 | 11:46 AM
tigerhawk_212's Avatar
tigerhawk_212
It won't cause any issues with the computer, but since you are talking long tubes, this will affect the original oxygen sensor location. Shorty headers obviously aren't an issue.
Headers are usually one of many basic things people can do to these engines to get a little extra power, without doing major engine work, so in that sense it's worth it. Search for some technical write-ups or videos to see if it looks like something you do or don't want to mess with. It is basically a "do it in your driveway" but that still doesn't mean it won't be a hassle.
Old Jan 15, 2016 | 09:01 AM
Kemicalburns's Avatar
Kemicalburns
the whole stock exhaust is a bottle neck frankly. Long tube headers can be used like mentioned the o2 sensor bung will need welded into the collector on one of the sides. you will also run into potential frame clearance issues or front drives shaft clearance issues.
shorties are a more direct swap but still a pain. dont go cheap here, a quality header will have a thick header flange to keep them from warping when heated up. this will ensure a proper seal. running quality gaskets like Percy's is a good call. also quality header bolts. I like running a 1" long header bolt for that extra thread into the head.
the Y pipe should be redone regardless and a hi flow cat put in place. a quality muffler shop should be able to do the exhaust work for a resonable price and all be mandrel bent. Dont bother going to a dual exhaust, you wont gain anything but a thinner wallet due to the cost of building the kit.
Old Jan 15, 2016 | 05:50 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Get headers coated...
Old Jan 15, 2016 | 05:54 PM
coachnichols
Why? I don't know jack about these so I'm curious, not arguing.
Old Jan 15, 2016 | 05:57 PM
ManfredVonRichtofen
Looks good, prevents rusting on the inside and out of header.
Old Jan 15, 2016 | 05:59 PM
ManfredVonRichtofen
maxedout94
Aug 22, 2017 08:53 PM
onthefloor4x4
Apr 30, 2010 07:35 PM
1994 F250: 351, C6
15
Jan 8, 2008 12:40 PM
MikeMc100
Exhaust Systems
May 15, 2003 04:17 AM
