Spark plug
Old Jan 10, 2016 | 05:12 AM
Johno.h's Avatar
Johno.h
Spark plug
Hi there I've just bought NGK plugs for my 351 Cleveland, just wandering if anyone knows the factory plug gap sizes thanks,
Old Jan 10, 2016 | 05:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't think the 351C was ever installed in a truck.
351M, from '80-'82 maybe?
Duraspark II ignitions called for .044" gap.
This should be shown on the sticker affixed to the radiator support.
Old Jan 10, 2016 | 06:14 AM
Franklin2's Avatar
Franklin2
He's in Australia. So he probably does have the cleveland heads on his truck. Would not have a clue what the Australian spec would be, but .044 or .045 would be a good place to start.
Old Jan 10, 2016 | 07:13 AM
FuzzFace2's Avatar
FuzzFace2
Just know the wider the gap the harder the box has to work to push the spark across it and could lead to the box failing.
Remember when HEI first came out the gap was .060? The modules would burn out so they closed the gap to .40-.045 I think it is.
Dave ----
Old Jan 10, 2016 | 08:04 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Oh
I'm on my phone, so I don't see signatures or much identifying personal information.
Sorry about that.
Old Jan 10, 2016 | 02:28 PM
Ralf z's Avatar
Ralf z
Yep, Cleveland motor in the Aussie trucks, last of the Clevos I think in the late part of 1986.
.44 to .45 is what I run as stated above.
Old Jan 10, 2016 | 02:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You seem to get *all the nice things*!
Old Jan 10, 2016 | 03:15 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
.40 to .45 gap will cause less stress on the module.
IMO, NGK are not the best plugs to use as they are a "high fire" plug traditionaly used in Asian built engines. I personally would try to source OEM Motorcraft plugs. And the nay-sayers chime in....3....2....1...
Old Jan 10, 2016 | 03:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have bought WAY too many Motorcraft/Autolite plugs that were bad out of the box in recent years.
Moved to V-power and am not looking back.
Old Jan 10, 2016 | 03:56 PM
WhatsAChevy?
Originally Posted by ArdWrknTrk
...0
Sorry to hear that....I have had good results being able to source OEM direct replacement Motorcraft spark plugs,wire sets,etc. direct from the manufacturer through authorized local distributors.
BTW.....What constitutes a "bad plug out of the box" ?
Old Jan 10, 2016 | 07:05 PM
FuzzFace2's Avatar
FuzzFace2
I would say not firing at idle or under load.
Dave ----
Old Jan 10, 2016 | 09:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Bodies that are not crimped tight on the insulators, electrodes that are not sheared clean or square.
It's a sparkplug.
I don't want to have to pack up and go to the parts store to grab another one because of your complete lack of QC.
What is "high fire"???
Maybe I'm just too old to know these things.
OrangeJuice
16
Apr 21, 2019 09:20 PM
1959_f100
Dec 23, 2008 10:25 PM
EXPLORER GUY
Dec 1, 2006 10:49 AM
bent rim
May 7, 2004 06:01 PM
dustinleavitt2000
Jun 15, 2003 05:29 AM
