Fuel Problem
Old Aug 8, 2003 | 01:35 PM
canadianfirefighter's Avatar
canadianfirefighter
Question Fuel Problem
I've got an 89 F150 4.9l with a problem. The truck will be running and then stall(Driving and idling) Through a series of checks I think I've determined it to be a fuel feed/ignition problem. I have replaced the in tank fuel pump, the filter, the fuel relay and plug, the ignition coil. I've checked for blockages in the fuel lines.
I'm lost! Can anyone help?
Old Aug 8, 2003 | 03:22 PM
drool's Avatar
drool
Fuel Problem
During that era (at least in my truck) there was a problem with fule pressure regulators in EFI trucks. I know mine was swapped and the symptoms were similar to yours.
Old Aug 8, 2003 | 03:31 PM
canadianfirefighter
Fuel Problem
Step number 43...Thanks, I'll try that!
Old Aug 10, 2003 | 09:55 PM
steve83's Avatar
steve83
Fuel Problem
Step #1 (always): pull the codes.
Step #2: read the Haynes manual troubleshooting section (Ch. 0).
On your truck, the ignition module is mounted to the distributor, and those are known to fail, so test it. Haynes shows how.
Old Aug 11, 2003 | 04:45 AM
canadianfirefighter
Fuel Problem
Thanks guys!
