Single to Dually Conversion
1999 to 2004 you could bolt dually wheels on and SRW axle. If they would clear the brakes I don't know. The OP's truck is a 2008+. In 2005 they switched the dually to 8 on 200 Vs. 8 on 170 for SRW.
Okay cool, thank you all for the help and information! Why does the front need an adapter? My rims are kind of deep dish but still strong enough to handle hauling, so I was thinking about just buying 2 more 35" toyos and 2 more of the same rims and trying to just use a connector to connect them to the rear wheels that I have now! Is that a possibility? I uploaded some pictures so you could see what I'm working with.
The front needs an adapter to run the standard dually wheel so that it will clear the brakes, and allow the truck to only need one spare. Is the bolt pattern on the unit bearing 8 on 170 still on the 2005 plus dually? I don't know, but it would need to be figured out if you can just bolt the dually adapter on the SRW axle without a unit bearing swap.
You can't use your existing wheels in the back. There needs to be a flat machined surface on each wheel to bolt them together. You could leave the fronts as they are, but then you'd need 2 spares, and to try to match the wheels to something in a dually variety, which is doubtful.
If you really want to do it the easiest way is to trade the truck for a dually. If you really want to keep your truck and convert it, track down a donor dually and swap the complete rear axle to yours. You may just need to swap spacers on to make the front work, but swapping the complete axle would likely be best as the gear ratios probably won't match.
Okay that makes sense. I found on arrowcraft they sell an adapter that connects onto the factory Dually wheel so I was thinking about buying the factory Dually wheels for the inside and then using my after market rims on the outside to make it look like both rims are aftermarket. Idk if this would work?
Then get custom width spacers built to place in between the inner dually wheel and your current wheel. Then bolt your wheel on the spacer. Your tires stick out a lot now. They will be way more stuck out after the conversion.
Your truck looks great. I wouldn't mess with it. I don't know if I would ever do something like that just for a dually look. Just get dually wheels and the 2 inch hubcentric spacer everyone runs
No that won't work in the traditional sense. The wheels you have now don't have the correct offset/backspacing to add another wheel inside. You would need to bolt a inner dually wheel that's the same wheel size as your current wheel on the inside. S o if you have 18 inch wheels you would need a 18 inch dually wheel. Dually wheels are narrower than your current wheel also.
Same way you do a dually spacer. Seriously If you're gonna dual wheel your truck go get real dually wheels and the required spacers fenders etc. Otherwise IMO you're just asking for issues. You're trying to make something work that really shouldn't be done. I said IMO I would leave your truck alone. It's a nice truck
What's the reason to dually the truck?
