Sponsored by: Halo Lifts
2015 F150 3.5L clicking noise while driving
Old 12-01-2015, 10:32 PM
leadfoot12000's Avatar
leadfoot12000
leadfoot12000 is offline
Think I have same issue
I am ever glad you posted this. Sounds like what I'm experiencing. I'll describe it as best I can and I uploaded a video to I tube so you can hear it yourself.
2015 F150 3.5L ecoboost 4x4 7weeks old 7500km(5000m)
First time put into 4x4 about 4 weeks ago. Initial engagement was very clunky. Heard and felt thumping noise when coasting but not under power. Only heard this noise when coasting in 4x4 high never in 2wd until now.
If I accelerate to about 50kmh and let off the fuel at about 42kmh it starts. Braking, shifting into neutral does not affect it. Frequency of knock changed with road speed.
Now in the last week it has started to do it in 2wd but ONLY WHEN IT IS 0c (32f) outside. When the tranny warms up it goes away.
So took it to dealer. They said an identification tag on the cat conv. was coming loose n dragging. They removed it. Took truck out to test and problem still there. Returned to dealer and took shop foreman out so he could here it. Left truck with them. Next day foreman took another new truck out and said it made same noise. Must be normal. I didn't agree but picked up truck. I then took a new f150 on a test drive myself and couldn't recreate the noise. This is when the temperature dropped and it started doing it in 2wd. Left tuck at dealer this morning and they have ordered a left front hub for it. I personally think it is an axle/transfer case issue. As you are having.
I uploaded a video of my issue to I tube for you to hear first hand. Please update with your progress and tsb #
Thanks for a great forum
Old 12-02-2015, 03:11 PM
leadfoot12000
Update: talked to dealership today. Now saying it is possibly front differential. From the location of the sound I agree. Now to see what happens.
Update: Ford wants them to open the diff and check it out rather than to replace entire component. Giving me truck back for weekend and will be dropping it off again on Monday.
Old 12-20-2015, 12:17 PM
codyg1983's Avatar
codyg1983
codyg1983 is offline
Originally Posted by dustinm104
Thanks, I'm having what I think is the same issue I was hoping to have a TSB # or something to give them to reference what you have so they don't just tell me "it's normal"
Sorry for the late reply. I don't have the TSB number and its been over a month waiting on parts. Still on back order according to my dealer. Not too happy about it but not much I can do other than wait. Ill see if I can obtain some info regarding the TSB number.
Old 12-20-2015, 12:25 PM
codyg1983's Avatar
codyg1983
Man, that is a bummer. It sounds like they are taking care of it. The noise mine is making is continuous while driving. It doesn't matter if it is in 4x4 or not. Keep us posted on what you find out. Thanks!
Old 12-20-2015, 01:55 PM
leadfoot12000
Fixed I hope
We'll finally got my truck back after two weeks in the shop. Looks like it is ok now. They replaced the crown and pinion in the front differential. Don't have a tsb number sorry.
Old 01-13-2016, 12:55 PM
codyg1983's Avatar
codyg1983
Just an update. My dealer finally got my parts in and I dropped off my truck today. Ill post when I get it back and let you know how everything turns out. Ill also try and get the TSB number.
Old 01-13-2016, 08:04 PM
Tom's Avatar
Tom
Tom is online now
Sounds good Cody, thanks for the update!
Old 01-17-2016, 12:23 PM
ctflyerfan's Avatar
ctflyerfan
ctflyerfan is offline
Wow. Same issue. Also thought it sounded like a rock in a tire tread. Anxious to hear update and TSB # as my dealer is a real PIA about everything except taking money.
Old 02-14-2016, 07:14 AM
ctflyerfan's Avatar
ctflyerfan
Cody
Did your issue get fixed? Were you able to get the TSB#?
Old 02-27-2016, 11:45 AM
codyg1983's Avatar
codyg1983
Originally Posted by ctflyerfan
Cody
After putting about 2000 miles on the truck, I can safely say the noise is gone! I don't see an actual TSB number on the paperwork but it says SSM 45452. Looks like they replaced a planetary assembly and a ring gear. My dealer took good care of me as usual even though it took awhile to get this issue figured out.
Old 03-05-2016, 07:35 PM
ctflyerfan's Avatar
ctflyerfan
Thanks. Hopefully this will help
Old 04-18-2016, 06:28 AM
MikeDVB's Avatar
MikeDVB
MikeDVB is offline
I'm experiencing something similar.
Did any of you ever feel any "dragging" or scraping feeling in your accelerator pedal (I know it's drive by wire but I feel it in the pedal).
  #28
Old 04-22-2016, 04:55 PM
1saxman's Avatar
1saxman
1saxman is offline
The video shows it to be at wheel speed so its obviously associated with the final drive.
  #29
Old 04-25-2016, 04:46 PM
Trevor Petersen's Avatar
Trevor Petersen
Trevor Petersen is offline
I have the same problem. I can hear the ticking only with the windows up from about 20-45. Not sure if its right, but my window sticker looks like it was built in July.
  #30
Old 09-02-2016, 05:30 PM
Derek Tanner's Avatar
Derek Tanner
Derek Tanner is offline
I think I have the same problem on a 2016 5.0
Mine had the same problem except it's not a clunking sound like was shown in the video it is more like your old school speedometer cable when it was running out of oil or. It's almost like metallic sound. Has anybody had any success getting it fixed?
Quick Reply: 2015 F150 3.5L clicking noise while driving
