Re-Building our 1978 Ford F150 custom
I am sure I can locate you a set in my local JY. Touch base with your upper Mo/KC area folks for a local deal with fellow members that will save you the road trip.
I live south of you by at least 2 ish hrs....But I am wiling to still get you a set of bolt and go set and all the other stuff you need if you have no luck.
Or I will gladly take you my secret JY shopping place. But you will have to ride in blindfolded of course. lol JK
How is the rig mechanically? ...Steering, brakes, suspension, and drivetrain reliability should be the main concerns. Have those systems and their subsystems been addressed?
LED headlights aren't really necessary to make it "roadworthy" per se. I mean, it's a nice upgrade but it is a luxury in my opinion.
Flowtech, Hedman, and Hooker are the most common header options. Surf over to our friends at Summit Racing. Aim for the thickest flanges and tubing among the options and your budget. Summit's house-branded welded mufflers are pretty much Flowmaster clones starting at around $35 each or so.
Tubing? Personally I like to weld my own using Summit's you-weld kit or just buy the bends and straight pieces you need and get to fabbing.
Having welder for these rigs pays back fast.. the less work farmed out, the more money that stays in your own pocket.... greenbacks you can use to get those LED headlights.
I have Flotechs and hate them. They come down under the truck way too far and require some funky bending to make the exhaust work. I also would have liked for them to have thicker flanges. I bought the headers from another member here on FTE for $100 brand new in the box, so I can't complain too much
Sorry for the bad picture, but it's the best I have at the moment. Notice how far down the Flowtechs come. The are one of the lowest hanging parts on the truck other than the axles, which doesn't make me happy, but it hasn't been a problem yet...
#29
That is because you used INSIDE THE FRAME EXIT headers....fenderwell exit is the way to go IMO. I have Hedman fenderwell exit's on my red truck. Easy to install (as long as your exhaust manifold bolts do not break off when begin removed) and easy to finish the rest of the exhaust system. No monkeying around the cross member.
#30
