1948 F-6 Engine question
#91
when I took the dist cap off I cranked the engine and saw it spinning. And when I pull off a coil plug and place to engine bolt I see a spark on what appears 1/6 of the time. The distributor looks fairly clean (rebuilt?). it a 226 6cyl flathead.
#92
#93
#94
I have number 1 at 6:00. I thought it was starting there when I took it off. There is a #1 mark on the dist cap. and I was fllowing the firing order on my replacement cables diagram (from LMC truck), but maybe I should check that now.
Thanx.
#95
No I haven't witnessed it running.
And how do I test for a leak? The tubes look new, and once I started to turn it over the fuel filter filled right up.
What can I do to validate it, both vacuum and compression?
Thanx.
#96
A quick, easy test.....pull the front (#1) spark plug and block the hole with your thumb while a helper turns the motor over with the starter. As soon as your thumb blows off the spark plug hole have your helper stop the starter. Take off the distributor cap and look where the rotor is pointing. The rotor should be near the plug wire going to the #1 cylinder.
#97
#99
For a compression test, remove all the spark plugs and the high tension lead from the coil. Tie the throttle full open and make sure the transmission is in neutral. Install the tester in #1 spark plug hole and crank the engine for four revolutions. Make a note of the pressure gauge results and repeat for the remaining cylinders. The difference in readings between cylinders should not be more than 10 - 12 psig. If there is, instill two squirts of clean engine oil in each cylinder and repeat the test. This will tell you if it is valve/head gasket or piston ring related.
#100
#101
good news, I took off the dist cap and spun it around to put #1 at 12:00, then reran each coil cable. It then tried to start with a little gas in the carburetor
It was so close but the battery gave out since its been in use trying to start it for some time now, and needs to be recharged.
The bad news is that rain is coming for the next 4 day, then Christmas.
How do you know where to set carb idle screw?
It might be flooded now...
#103
#104
It's a regular screw, clockwise is in, counter-clockwise is out. Don't screw it in hard, use your fingers. I've always heard 1-1/2 turns out to start.
If you mean the idle speed screw, look down the carb and screw in the idle speed screw til you see the throttle blade is visibly open. That will let it start at least.
Was the engine at TDC on #1 when you repositioned the distributor?
#105
I'm referring to the set screw on the outside of the carb around the bottom facing outward (passenger side).
I didn't check when I put the dist cap back on. I basically took off the cap, reversed it, and put the coil wires back on in the correct firing order.
