Speed Daddy Stainless headers for a 351w
Old 09-03-2015, 08:05 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
Originally Posted by Dean06919
does anyone think these will fit the F350 or is something different between the F150-F250 and the F350?
No difference between those models, the headers will fit assuming it also has a 5.8L engine.
Old 09-03-2015, 06:56 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
The difference would be a solid front axle if it is a 4x4...
Old 09-03-2015, 09:12 PM
choate's Avatar
choate
choate is offline
If you get a chance, will you please post the link to the cheaper seller?
Item Number 161743837990 if the link doesn't work
Seller is wzho3115
http://r.ebay.com/wXXWqC
Old 10-13-2015, 10:23 PM
86f150lariat's Avatar
86f150lariat
86f150lariat is offline
So did anyone buy these? And what size is the reducer to whoever put these on.
Old 10-14-2015, 07:29 AM
Toplait's Avatar
Toplait
Toplait is offline
Old 10-14-2015, 09:32 AM
choate's Avatar
choate
choate is offline
I have them in my basement. I'm gonna have a shop fit and install them probably in the next week depending on when they can get to it
Old 10-21-2015, 05:36 PM
choate's Avatar
choate
choate is offline
One thing I'll add here and I'm still waiting on the shop to find time to install these is that I purchased a starter heat shield wrap. It's $20.00 from Jegs or Summitt. Cant wait to get these things on and hopefully all this saved the shop a bunch of trouble. I have also purchased the Stage 8 locking header bolts that use allen wrench style bolts to tighten.
Old 11-21-2015, 09:38 AM
choate's Avatar
choate
choate is offline
Originally Posted by Toplait
Well the verdict is in. Got these installed by a performance shop. I've only driven the truck about 10 miles since because now I have e fan problems but that's another story. The shop charged $425 for the install then the muffler shop charged $250 to make and fit the new mid pipe. I'm pretty happy with them for sure but a word a caution......The shop asked what kind of headers these were because he would not recommend them if you don't have the tools to modify them quite a bit. He said exactly what Toplait said. Mainly the biggest problem is the header bolt holes don't exactly line up. The egg shaped holes have to be drilled out more then he had to do some bending too because when he dropped the truck on the ground they were hitting something (frame or driveshaft I think). Also he said he didn't feel comfortable using my stage 8 locking header bolts because the flange on the headers is so thick there were only a couple threads holding in the bolts so they used their own with big stainless washers and lots of lock tite and copper RTV sealant. If there are any questions just let me know
Old 11-28-2015, 11:15 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Not too bad, I've bent many a header for driveshaft clearance. If the welds on the headers hold up you'll never have to get a new set, so what's done is done. Steel headers last ~10 years give or take a few depending on driving conditions and quality.
How about throttle pedal feel?
Old 11-28-2015, 11:35 AM
choate's Avatar
choate
choate is offline
Yep u are right. Whats done is done and Im really happy with them. Look and sound great too! I had them install a radiator and wire an e fan at the same time. The controller I provided was faulty per the shop so they wired it on high speed all the time so I need to get a controller wired in BC the fan is too loud right now.
To answer your question the truck woke up big time. Lots more power and torque. I buried the needle the other day on the back roads easily with no problem.
I'll add some pics of them on the truck here once it quits raining. Been raining and supposed to continue for a few days. The headers look real good on there. Already starting to have that blued look
Last edited by choate; 11-28-2015 at 11:39 AM. Reason: Added a sentence at the end
Old 11-28-2015, 01:32 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
What thickness were the flanges? That is SUPER important and they didn't even list that
Old 11-28-2015, 01:48 PM
choate's Avatar
choate
choate is offline
The person I ordered from was clueless. I didn't measure but its thick. I can try to get a tape in there and measure if you want. Honestly if you have the ability to drill out the head bolt holes as needed I would recommend these. Can't beat $190 304 stainless steel. The welds, finish, egr hole, o2 bung etc all look and fit well besides the head bolt holes not lining up
  #28
Old 11-28-2015, 04:21 PM
jaagen's Avatar
jaagen
jaagen is offline
How about calling them back and inform them that the bolt holes don't line up properly. How much did you have to open the holes up?
  #29
Old 11-28-2015, 05:37 PM
choate's Avatar
choate
choate is offline
I honestly dont know. I'll ask the race shop. The person I bought the headers from didn't even speak or write clear English. U should see the box the headers came in. Literally had Chinese lettering on it
  #30
Old 11-28-2015, 08:39 PM
Toplait's Avatar
Toplait
Toplait is offline
I use them.... You bought the wrong ones.
Quick Reply: Speed Daddy Stainless headers for a 351w
