Do I need a new radiator or...?
#121
Quick update:
I should be updating you with good news by now, but alas. The radiator that was ordered was a 24" - though it was all metal and correct in that department. Then the second radiator was the right size, but someone put a plastic and aluminum radiator in the box that should have had an all metal one.
Then I had to go out of town, which brings us to now. Now she sits waiting for my return and I wait for the phone call saying they got the correct size and correct type of radiator in so I can pick it up when I'm back.
#122
#123
I'm getting a brand new all metal one for $290 which includes tax. Doesn't seem to shabby for the area I'm in.
#125
I got the call that the radiator is in, however I am not. Home next week and I can't wait. I've been itching to get back in the water. (:
#127
Update:
I got the new radiator in and wanted to run distilled water through. All went well! Typically after about 20-30 minutes of running it would get hot, but it hasn't yet.
The only bummer part is that there is still rust colored water coming out. Even after flushing and back flushing.
I've flushed it again 3x with distilled water, but I think I'm going to have to do it a lot more times.
Is it harmful to use hose water while I do this? I wanted to try and avoid it, but I have a feeling I'm going to need about 12 more gallons of distilled water just to flush it, or more.
#128
Update:
#129
on
I've used hose water everytime I've ever flushed anything.
What you can do if you haven't already, is remove the thermostat, replace the water neck and upper hose, and run the hose into the lower hose and run the engine while it flows out of the top hose. Go until it's clean.
#130
I'm going to look into that more now.
#131
Does it matter if I leave the lower hose attached or not? I guess if I left it attached on the engine side I wouldn't have water everywhere.
Back to the ol' fun in the sun with the hose routine. (while googling about freeze plugs)
#133
I did not replace those. I tried to Google it and the only time I saw them being replaced was when the engine was out out of the truck. I'm not entirely sure how to remove them without dropping them down inside, or how to put the new ones without the same results...
The freeze plugs you mentioned here can easily be replaced if they look like they are rusting out from the inside. Poke 'em with something metal like a punch. Not with a hammer but not a love tap either. If the punch breaks through they are rusting away on the inside and would soon create a hole and leak. Let us know if you want to change 'em. One of us will explain how.
#134
I meant the drain plugs approx. center of the block down by the oil pan, just above it. You unscrew those and all the rust and sediment in the bottom of the block's cooling jackets will come out. You might have to keep poking something in those holes to keep them from getting plugged up from the sediment passing through them.
#135
Distilled is the water of choice because it has no minerals in it. Minerals build up over time is all. Where I live our hose water was snow only hours ago so about the only minerals we have (which is nearly none) are what wash off the rocks as the snow melts and the water runs down the mountains. The tap water here is so soft that the chem labs use it as distilled water. Now if you're pumping it out of a well and it's loaded with heavy minerals like iron, etc. then you'll want to get distilled water in there eventually. But don't waste it flushing trash out of your engine block.
A cooling system is nothing more than a bunch of passageways that coolant (water/antifreeze) flow through to take heat from the engine. It's not a precision system like the oil where you can't afford to have hunks of stuff floating around in it. You won't hurt anything long term using tap water.
Your system doesn't need to be spotless. It would be nice but it just doesn't matter. What matters is that it doesn't over heat. I just drained my system to put new manifold gaskets in it. I've owned this truck 17 years and every time I have to drain the coolant it comes out with a tad bit of rust. When I pour the old coolant back in I just don't put in the last few ounces that are loaded up with rust dust.
