97 Aerostar LR. Axle shaft
Well after 451k the left rear axle bearing has started to grind and the shaft is bad too. While I'm on my third RRear axle this left side will be the first. My axle is 8.8 3.55 gear. I'm looking at E69z-4234a , dorman 630-230, or motive gear1456 as part numbers. Info shows 7.5" as those part numbers. Can anyone verify before I order. Engine is 4.0
Probably what I would do. Is the Ford number discontinued? Call the Ford dealer with the VIN in hand and ask if the axle is available. If it is not, politely ask him to give you the Ford part number that he says your van needs. A lot of your part stores can give you the direct cross-reference of what they sell by entering the Ford part number.
Quick update. For some reason the 8.8 and 7.5 axles are the same. I ordered the motive gear 1456 from Summit and did the axle, bearing and seal. Upon inspection the bearing had ground the shaft leaving a sludgy metallic type paste in the bearing race. I had to transfer the studs. Used Harbor freight bearing puller set and slide hammer.
Piolet
1999 to 2016 Super Duty
03-19-2013 11:17 AM
yellow tonka truck
04-09-2004 12:31 AM
