C4 Transmission Rebuild
Old 07-06-2015, 07:20 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Originally Posted by qman
Ultra, I'm like you bro. Tore the C6 out just cuz I knew I could. I'm sure I could cut the 9 hr job in half next time around hahahaha. All I did was fix leaks. Didn't rebuild anything. But I stood there looking at it thinking I'm sure I could do it, just didn't want it to be one of them deals where parts end up all over the place.
Let me know how it goes and let me know if you think it's worth the $1200 price tag a local shop quoted me. I only got one quote so who knows, there might be someone out there with a lesser quote.
I know a man's gotta make a living as I do not work for free. The rebuild kit is int the $100 ball park and it takes 12 hrs that's in the $100 hr range. About typical I guess but that's around where I start to figure I could just pay myself.
Never done one myself. But I wouldn't be afraid too. Pick up on a YouTube video or two and/or the above mentioned manuals. Read through it 1st to see what special tools are required. Wash your hands and go after it.
I stand by my sig.
Old 07-06-2015, 08:07 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
I had the C4 in my galaxie partially apart for cleaning. (It got filled with water...) it looked pretty simple as far as a tranny goes. Much more so than my AOD did. But I never really got into the hard parts.
Old 07-06-2015, 10:33 PM
marinesuperduty's Avatar
marinesuperduty
marinesuperduty is offline
Well you guys are all fancy with your DVD players and stuff lol. I rebuilt mine without any DVD or books. And it worked better than it did before. Not right, but better than before hahaha. Either way, I'm dropping the valve body tomorrow to see if I got those ***** in the right place. Anybody know where they go? The diagram I got wasn't a ford diagram, and mine only had two in it when I took it apart but the diagram called for three...dunno if 3 is right or not...
Old 07-07-2015, 12:11 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Old 07-07-2015, 01:26 PM
marinesuperduty
Thanks bud. I guess I only need 2 then huh? I was hoping to say my truck is so cool it's got 3 ***** hahaha
Old 07-07-2015, 03:25 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
"Swing lowww, sweet Chariooot".....
Old 07-07-2015, 05:23 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
Originally Posted by JEFFFAFA
I guess my 4R70W is really 'studly.' It has (8) ***** in it.
Old 07-08-2015, 08:10 PM
marinesuperduty
Ok fellas, I have my valve body out, just for my own piece of mine, you guys are 100% certain I'm supposed to put the above pictured ***** in my lower valve body, and no ***** in my upper valve body. Just want to make certain, I'm tire of dealing with this trans issue hahaha I want to drive my truck dang it!!!
Old 07-08-2015, 08:15 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
yes.... pack with a little vasoline to hold em in till ya get it bolted back on
Old 07-08-2015, 09:49 PM
marinesuperduty
Well I think I found my problem. The first time I rebuilt it I put the wrong gasket in between valve body halves. Looks like a lot of pressure built up too, because there's a little tearing of the gasket in a few spots. Either way, I put the right gasket, 2 *****, clean valves back in it. Put it back in truck tomorrow. Hopefully the wrong gasket stopping fluid flow through the VB was my problem.
Old 07-08-2015, 10:40 PM
351Cleveland C4
There is extreme pressure in the valve body. Sometimes close to 400psi I think
Old 07-09-2015, 10:57 AM
qman's Avatar
qman
qman is offline
there's a gasket under the valve body?
  #28
Old 07-09-2015, 11:56 AM
marinesuperduty
There's a gasket and separator plate between the upper and lower halves of the valve body.
  #29
Old 07-09-2015, 01:47 PM
qman's Avatar
qman
qman is offline
I wonder if that's why my C6 shifts slow into drive but not reverse. I had the valve body off one time to put in a new shift shaft seal and then I put the valve body right back on. Wonder if I shoulda put a new gasket in there. I didn't even notice one.
  #30
Old 07-09-2015, 02:44 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Doesn't the master kit come with directions for overhauling the trans?
Like what ya would get with a model airplane kit? Way back in the day
when Fram was still American I used a lot of there Master kits. Everything
was there and the directions where spot on. Like it told you to soak the
clutch disks over night in ATF and stuff like that. It made the overhaul
easy and fun. I prolly have done 200 Ford Dodge and GM trannys
from the 60's, 70's, and 80's with never a problem with any of them.
We didn't have internet or DVD's back then and what came with the
kit was all we needed. Just sayin
Quick Reply: C4 Transmission Rebuild
