Exhuast Manifold Gaskets
Old 06-03-2015, 03:40 PM
fordf350man's Avatar
fordf350man
fordf350man is offline
Okay. The muffler shop is putting in my new exhaust manifolds on Friday when they have a full crew again. There is a couple cracked bolts and I honestly don't want to do this job in my driveway and the heat so I have decided to swallow my pride and pocket book and take it to the shop and let them have all the fun. They are going to charge me an arm and a leg for labor but its the cost of convenience I guess to have this truck run right after so many years of not (this should be last thing since I have done a full tune up and she is running like a champ).
So my question is what gaskets to use? I have read differing opinions on this. I am going with stock style dorman ones (so if I do do the MAF mod I can just plug the speed density holes with supplied plugs) so they are cast iron like the engine. I have read on here many think that if its cast iron manifolds it is better to just bolt it straight to the engine and just get rid of the gaskets all together. Also I have heard remflex gaskets are good (already but a set from amazon but I can always return for a small fee). So what have you guys done when replacing with cast iron manifolds? If I was going the header route this would not be a question and I would be rolling with the remflex gaskets.
Thanks in advance!
Old 06-03-2015, 05:24 PM
choate's Avatar
choate
choate is offline
If you don't mind me asking, what are they charging you? I'm thinking of getting some shorties that bolt up to the stock Y and it would basically be the same job but I have yet to ask around since I have a few things I need to get installed first but I am likely going to let a shop do it too and curious how bad it is. If it's too much I will have someone help and do it myself
Old 06-03-2015, 07:32 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
These are for a big block, but this is what I have on my truck now. My manifolds were warped pretty bad and these sealed them right up. I had problems keeping the bolts tight, so I installed these:http://www.ebay.com/itm/Vibration-Pr...3e572d&vxp=mtr
They worked like a charm!
Old 06-03-2015, 07:56 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
There's not way that manifolds would seal properly against the motor without gaskets at this point. I also think you're throwing good power away by not putting on headers as long as you're replacing the manifolds anyway. Use copper or steel core gaskets. They won't blow out immediately like the junk paper ones.
Old 06-03-2015, 10:03 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
Those are not "speed density holes"....those are for the Air Injection system. Has nothing to do with the engine fuel/air control.
Old 06-03-2015, 10:17 PM
fordf350man
Learn something new each day on here. Either way I don't think I want to delete the air injection system. Supposedly exhaust doesn't smell good after right? Any shorties with these already on them before I spend the money on getting these replaced?
Old 06-04-2015, 05:48 AM
rla2005's Avatar
rla2005
rla2005 is offline
No smell issues that I am aware of or experienced.
Old 06-04-2015, 07:21 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
I deleted the smog pump and associated AIR system crap 5 years ago. No additional smell, and it's passed emissions every two years since. RI still does sniffer tests on OBD1 vehicles. (yay)
From what I understand, the AIR system is only operable for the first few minutes of run time on a cold engine. If you want to delete it, have at it.
Back to the gasket issue... I've tried a few different types, Remflex, Percy's, and now Fel-Pro. So far, the Fel-Pro gaskets have been the least problematic in terms of longevity, and not having to re-torque bolts after every 20 mile trip.
Summit sells a set of shorty headers with the EGR tube fitting on passenger side header, but I haven't seen any with the AIR fittings in them. That's what I have on mine and they've been great.
Old 06-04-2015, 04:53 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
No need for gaskets with new manifolds unless you ran the truck for 20k or so with broken bolts and it eroded the head.
The didn't have them from the factory, so there is no need now with new manifolds
Old 06-04-2015, 04:54 PM
fordf350man
Interesting. Well. I am rethinking this whole deal now. Clearly I need to spend some time looking into the air injection system delete and smog delete I just read a few places not to do it so I did not do my due diligence on the subject. I have obligations this afternoon but I will look into it tomorrow and decide if I should send these manifolds back. If I do might as well send the remflexs back and get felpros if you have experience with all of them. felpro I have always heard is decent. Dang. wonder how much shortys are going to be..... If I am going to spend the money though might as well do it all the way.
Old 06-05-2015, 10:45 AM
Bob Gervais
It was a few years ago when I bought mine from Summit, but I remember them being less than 200 bucks for my 5.8.
They won't be listed for an F350, mainly because of the AIR tubes that go into the manifolds. The shorty headers don't have provisions for that. But, if you're going to delete the AIR system, you don't need them anyway.
Here's a link to the shorties I bought:
http://www.summitracing.com/parts/su...rd/model/f-150
Old 06-05-2015, 01:59 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
I bought the same ones. They send you Pacesetter shorties. Repaint them immediately when you get them.
Old 06-05-2015, 05:36 PM
fordf350man
What paint did you use? Yeah I guess I am going to go ahead and delete the air injection system. Seems pointless. I thought they were part of the speed density system for some crazy reason.
Old 06-05-2015, 09:09 PM
fordf350man
Pronto Muffler wanted $860 plus tax for complete job with parts (manifolds not headers). They are known to be a good shop in the area and have been there for years. Did many of my friends exhausts including some for my gearhead friends. I got my high school truck exhaust done there back when I was more like my grandpa then my dad driving a Chevy 1500 Z71, got true duals flow 40 series, boy was that truck sweet until it hit 120K and everything on it started breaking. That said that shop is also known to be a little pricey. Good quality comes with a price. I found a shop for $200 for just the labor. They looked at it when I bought some tires so they know about the two broken bolts already. Sketchy shop off Harry Hines (the old red light district here) so guess who is going to stand there while they do it..... Will be a fun 2-5 hours chain smoking cigarettes in the heat. Going to bring a chair and a fan. They are going to hate me but I don't know these guys from adam.
Old 06-05-2015, 09:11 PM
fordf350man
I just bought these. Think the heat resistant paint at Home Depot will be decent? Also ordered some felpro header gaskets to use with those ARB header bolts I bought. Had a $20 off coupon for summit anyways.
Quick Reply: Exhuast Manifold Gaskets
