Electric Fan Questions
Old 05-07-2015, 04:53 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Originally Posted by shaker666
This is a good point and a valid one when the vehicle is driving at highway speeds where the ambient airflow will hopefully be enough to turn the fans off.
It probably isn't an issue with modern, densely finned aluminum radiators where most of the oncoming air is attenuated. However, our radiators have large gaps and significantly more thru-flow. Food for thought.
Old 05-07-2015, 10:48 PM
61steven's Avatar
61steven
61steven is offline
That's another thing that I had not considered! So other rad shrouds have flaps that open to let airflow pass through?
Old 05-08-2015, 12:45 AM
HIO Silver's Avatar
HIO Silver
Yup. The flaps are pushed open by oncoming air at speed. When the fan is engaged at low speed, the negative pressure ("vacuum") draws them closed so all the air is drawn through the fan.... most effective when the entire radiator is fully backed by a shroud:
Old 05-09-2015, 11:04 AM
61steven's Avatar
61steven
61steven is offline
The more I think about it, I think keeping the mechanical fan and buying a shroud would be best. The mechanical fan cools fine when the truck is at least moving.
What shroud do I need? JBG lists one but the dimensions are different than what I had measured. From the holes already in my radiator it comes out to be around 28x20.
Can anyone point me in the right direction on which one to get?
Old 05-10-2015, 11:44 PM
406angler's Avatar
406angler
406angler is offline
I run this with a two speed 19" fan off of a late 90's lincoln:
Amazon.com: Hayden Automotive 3654 Adjustable Thermostatic Fan Control: Automotive Amazon.com: Hayden Automotive 3654 Adjustable Thermostatic Fan Control: Automotive
I had pretty high temps in traffic so I completely removed my clutch fan and replaced it with the electric one... had it on for two years with the stock alternator and an optima red top. No problems whatsoever with the alternator struggling to keep up. It's easy to wire up and just set the temp that it kicks on with a small screw driver... the higher speed kicks on 10 degrees higher than the low, and it also has a manual override wire which I have on a switch for passes when towing. works great; haven't overheated yet.
Old 10-26-2016, 05:51 PM
wooddyusa's Avatar
wooddyusa
wooddyusa is offline
Hey guys. Reviving this old thread....I picked this up out of a Lincoln town car today while I was at the pick pic n pull. I'll be going back for a 3g alt at some point. Will this be a good fan for a Highboy with a 390? supposedly it's got internal resistor. does this have an internal temperature controller? Is it a 2 speed? Thanks for any info you have on this.
2001 Lincoln Town Car.
Old 10-26-2016, 07:16 PM
HIO Silver's Avatar
HIO Silver
If it is a two-wire plug then it is typically single-speed.
.. three-wire and it's more than likely a two-speed fan.
I know, fire it up!
Old 10-26-2016, 09:07 PM
good to doo's Avatar
good to doo
good to doo is offline
Here,s what I did No over heating problems Yet.
Old 10-27-2016, 10:48 AM
wooddyusa's Avatar
wooddyusa
Nice. This is a 3 wire fan. I'm assuming 2 speed. I have no clue how to wire this thing up. I'll look into it when I get the 3g conversion done and I'm ready to give this a shot. I've heard changing the alt isn't that big a deal. Off to the pic n pull again.
Don Bordeaux
1997 - 2003 F150
06-07-2018 07:49 PM
quincyj34
09-13-2015 01:21 AM
rustywheel68
03-13-2012 11:40 AM
Woodsman_30350
07-02-2009 10:24 PM
John - NNY
12-31-2005 11:56 AM
Quick Reply: Electric Fan Questions
