Missouri Chapter Join Chapter , Leader:77&79F250
BORDERBUM'S 79 F250 4x4 Explorer
  #91
Old 02-01-2017, 09:45 PM
BORDERBUM's Avatar
BORDERBUM
BORDERBUM is offline
before we installed emergency brake cables a while back...I am behind on pics I know...
RC welding nuts and bolts on so that taking the hitch and bumper off in the future is a ton easier
  #92
Old 02-01-2017, 09:54 PM
BORDERBUM's Avatar
BORDERBUM
another full work day
  #93
Old 02-01-2017, 09:57 PM
BORDERBUM's Avatar
BORDERBUM
cab light install
cab light install
cab light install...still needs wired...if I can get down there tomorrow...it will be done
  #94
Old 02-01-2017, 10:01 PM
BORDERBUM's Avatar
BORDERBUM
a little bad arsery!!
of course these last few pics are after the grill install today
  #95
Old 02-01-2017, 10:07 PM
BORDERBUM's Avatar
BORDERBUM
last pic of the night before I left. Cab lights are not yet wired but every light on the truck work besides one reverse light....and its a new socket...so im hoping bulb
  #96
Old 02-03-2017, 11:26 PM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
Awesome Blossom!
  #97
Old 02-04-2017, 08:35 PM
BORDERBUM's Avatar
BORDERBUM
cab lights are wired and working,
  #98
Old 02-04-2017, 08:39 PM
BORDERBUM's Avatar
BORDERBUM
cab lights wired and working
rear spring bolts all tightened
tach installed but not wired...
RC did some Distribuor wiring done
  #99
Old 02-04-2017, 08:40 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,363 Likes on 2,501 Posts
All the little things add up to the big overall project being done before you know it. Looking good!
  #100
Old 02-04-2017, 08:51 PM
BORDERBUM's Avatar
BORDERBUM
Thanks Rich. All RC's tools and knowledge make this a lot easier on me. I can do this stuff....but RCs knowledge takes hours off my time.....hours is time and hours ends up days ....then weeks....etc
  #101
Old 02-04-2017, 09:08 PM
77&79F250's Avatar
77&79F250
Yes I need to get Alan and RC up to my place again, I get all kind sof stuff fixed with them up here together.
  #102
Old 02-15-2017, 09:04 AM
BORDERBUM's Avatar
BORDERBUM
Not a lot of big stuff left for this phase... By this phase I mean everything done to pass inspection and the interior finished.
Thrush Turbo 17715 mufflers bought. 2.5" inlets/outlets.
New 4 way bought
New horn relay ordered
Stuff RC/we/I ...did last Sunday..
Fixed reverse light bulb on driver's side
New antifreeze
Ends on the hard fuel lines finally
Tach wire installed
Distributor power wire
Tacked up some wiring
We also added some stuff to our list before it leaves RC's.
Paint interior
Fix the 4x4 with shaft from parts diff I have.
  #103
Old 03-04-2017, 08:40 PM
BORDERBUM's Avatar
BORDERBUM
Starting our job today....the input shaft for the 4x4 is missing.....
Taking off the diff cover....please let there not be a mess of metal be all over the place.....
Close up of no input shaft
The job is now a lot more involved....check bearings , new seals , of course the shaft.., etc etc... but this is ok with me.
  #104
Old 03-04-2017, 08:44 PM
BORDERBUM's Avatar
BORDERBUM
Forgot to mention the fact that I yanked the brake calipers out ...one set of pistons were wearing the brakes uneven and and going to replace both of them now including the brackets. For only $4 more....
  #105
Old 03-05-2017, 09:10 PM
BORDERBUM's Avatar
BORDERBUM
This is literally out the back door of RC'S shop....beautiful . Would give me more peace if i wasn't so dang busy lol.
Second picture is the front diff taken apart. What we found? A new set of gears...new bearings new seals....all put in with no drivers side input shaft....
Going to clean it all up put new seals on the outers..new warn locking hubs and calipers and brakes and some fresh paint here and there and put it back together again.
Quick Reply: BORDERBUM'S 79 F250 4x4 Explorer
