Tomahawk's F100
#1021
In the last update I forgot one pic of the foam weather strip shroud.
Wiring is 99% done!
AC hoses have been cut, marked and sent back to Class Auto Air for crimping.
Fender gaskets are done.
The hardest part with the windshield installation was putting the gasket on the glass.
The rope trick was easy!
So far so good!
Wiring is 99% done!
So far so good!
#1023
#1025
Sorry about the crappy phone pic.
I filled the stock heater core holes and drilled two new holes under the obround cutout on the passenger side.
The obround hole is used for the AC lines.
#1028
Received 5,172 Likes
on
#1030
Thanks Darren! I hope to be driving it this month.
I could not have done all this without my two helpers!
Thank you!
#1032
#1033
Nice work Tomahawk. Seems to be coming along very nice. I do have a question. When you put the glass in. It looks like you ran the string around from the top and the two ends met in the middle at the bottom side of the glass.. Did you sort of sit the bottom side in there and start pulling the string while applying pressure to the glass? Just curious if you had any issues in the corner areas.
Thanks
Thanks
#1034
Fantastic work, as always.
I see you taped/marked your a/c lines/fittings. The same deal I did when I sent mine back to RetroAir to crimp mine. Helps keep them clocked so they don't get a twist in them. For the life of me I can't understand why my local Parker stores could NOT crimp their own barrier a/c line? It's too commercial/OEM and they do not have the dies to handle it.
Dealing with stainless braided a/c line working on the Ford powered ****** currently. Just like typical AN line but it is nylon line instead of rubber. The bad thing I've discovered is when installing the ends, the fitting HAS to rotate so your 90* ends don't end up in the right location and you have to give the line a twist? Don't know what is going on? If you are working with straight ends, no biggie. But any curves and it rotates out of place. Ugh. I've tried marking them and figure how far it has to turn and then reset it? Only 4 more to go and they are short and no room for "twisting". Time will tell.
#1035
Received 3,619 Likes
on
