leveling kit
Old Mar 19, 2015 | 10:35 PM
darikfine's Avatar
darikfine
leveling kit
Got a 01 f250 4x4 extended cab that I want to lift. What's a good size to get.
Old Mar 20, 2015 | 08:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE.
Pretty generic question. My truck works pretty well with a 3.5" level in the front and 35" tires.
I think you probably need a 15" lift and some 48" Michelin XML's.
Or something in between.
Old Mar 21, 2015 | 09:57 AM
JOHN2001's Avatar
JOHN2001
8" lift on 38s was impractical now I'm running a 6" lift on tiny 35s and its useable but still not perfect for a DD. If I had to do it again I would go 4" lift on 35s. That way it's enough to fill the wheel wells and look good. Plus still usable in every situation. With the 8" lift my SD measured 7'-4". With a 6" lift and not an SD on 35s my dodge measures 7'-2". Both measurements from the ground to the highest point of the cab.
Old Mar 21, 2015 | 10:33 AM
HD Rider's Avatar
HD Rider
Since your thread title is "Leveling Kit";
This is what I have. F250 1999-2007 Ford 1.5" Front Lift Shackles | Jack-It, The Suspension Experts
Simple cheap and won't affect your ride.
Old Mar 21, 2015 | 06:25 PM
kefrko's Avatar
kefrko
Originally Posted by HD Rider
Since your thread title is "Leveling Kit"; This is what I have. F250 1999-2007 Ford 1.5" Front Lift Shackles | Jack-It, The Suspension Experts Simple cheap and won't affect your ride.
What size tires are you running with that leveling kit?
Old Mar 22, 2015 | 12:34 AM
HD Rider's Avatar
HD Rider
265/75R-16 stock size tires.
I did not go big because I didn't want to adversely affect towing a 5er.
kickstand03263
Oct 13, 2016 05:59 AM
1992 Ford Junkie
Sep 8, 2012 10:17 AM
tn00944
6.7L Power Stroke Diesel
May 12, 2012 08:46 AM
74redone
2004 - 2008 F150
38
Aug 23, 2010 02:00 AM
