67 f100 with 352
Old 03-14-2015, 07:50 PM
wolfs86F100's Avatar
wolfs86F100
wolfs86F100 is offline
67 f100 with 352
ok guys here we go my son has a 67 f100 we had to trailer home as we got to looking at one time there has been a fire under the hood and the harness has been butchered something awful even under the dash ,looks like they tried to splice the harness under the dash but nothing works correctly.not knowing any better until now we found a 72 at a local junk yard and get the harness out of it only to get home and realize this harness is very different is there any realistic way to make this harness work?almost to the point of buying rolls of wire and just remanufacturing a new harness from scratch , we priced a new harness from LMC and its 600 dollars so that isnt an option right now any other suggestions?
Old 03-14-2015, 08:31 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Pull another harness from another 67 truck.
Old 03-14-2015, 08:44 PM
wolfs86F100
kinda what i figured was hoping for something else 67s are hard to find in Alabama
Old 03-14-2015, 08:45 PM
351Cleveland C4
They are harder to find everywhere. I'm not sure, but 68-69 might be compatible. I know 70-72 were different.
Anyone????
Old 03-14-2015, 09:00 PM
Gembone's Avatar
Gembone
Gembone is offline
closest would be the 68-69 since in 70 the cluster went to flexible printed circuit boards.
Also if you have all gauges, make sure you get a harness with all gauges and not idiot lights
Old 03-14-2015, 09:01 PM
wolfs86F100
that is correct did some research after we saw we didnt get the right one 70-72 has a few more wires than the 67-60 and different connectors
Old 03-14-2015, 09:02 PM
wolfs86F100
thanks Gembone
Old 03-14-2015, 09:04 PM
Gembone's Avatar
Gembone
Gembone is offline
Most of the systems one these trucks are fairly simple. If you have any wiring experience you should be able to string your own.
Old 03-14-2015, 09:07 PM
wolfs86F100
i can do that i am a 30 year mechanic just not on cars i work on big trucks and really dont have the time to do that but may have to do just that lol
Old 03-14-2015, 09:09 PM
wolfs86F100
i like that step side by the way i have an 83 step side with wood bed that i will be starting on before to long
Old 03-14-2015, 10:44 PM
Mister_King's Avatar
Mister_King
Mister_King is offline
If you want something new, check out Ron Francis Wiring
I am thinking of purchasing on of the wiring harnesses from him.
Brand new and fairly priced. About $360 for a basic harness.
Not bad compared to $600-$800 from competitors.
Gembone's Avatar
Gembone
Gembone is offline
Thanks, It still has a wood floor under a thick steel plate someone else installed. Looks mostly rotted from what I have seen from underneath. One day I might put it back to wood.
theastronaut
01-15-2014 07:38 PM
appy34
11-17-2010 02:36 PM
Take2
11-15-2006 06:24 AM
Bartholomew
11-03-2005 12:38 PM
bsbates
11-28-2002 09:08 AM
Quick Reply: 67 f100 with 352
