ponykilr's '96 F350 Build Thread
Old 02-18-2015, 04:22 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I am amazed at how they can sell that for $8.
The clevice is $20 something
  #77
Old 02-18-2015, 08:04 AM
ponykilr's Avatar
ponykilr
ponykilr is offline
Yeah I dunno. Maybe a buyout of some stuff. His store has a lot of things that seem to be small lots of items cheaper than the average. Being solid, I am not worried even if it's foreign but I am not sure where it actually comes from. The clevis has rating marks on it.
  #78
LeoJr's Avatar
LeoJr
LeoJr is offline
Get a real tow strap, the kind that stretches, the kind that doesn't have hooks on the end, rather a loop. You will never use a chain again.
Don't use a hitch. Just shove the loop into the receiver and run the pin through the loop. Not suggested for tugging at an angle, but much simpler when just towing someone.
  #79
Old 02-18-2015, 11:25 AM
Iversen-fords's Avatar
Iversen-fords
Iversen-fords is offline
NEVER USE CABLE
NEVER USE CABLE!!! I'm still kicking myself in the a$$ about this
  #80
Old 02-18-2015, 01:12 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Depends on where you get them, and what rating they have.
For that size, my local marine supply sells them for $5 or so. I think they're rated for 8k lb.
The ones I buy from McMaster that are the same size, but rated for lifting, are $50 and up.
  #81
Old 02-18-2015, 03:20 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
Originally Posted by Iversen-fords
NEVER USE CABLE
Looks like failed welds on the hitch. The square steel just broke like a twig. That is not normal. Was there lots of rust inside?
  #82
Old 02-18-2015, 03:37 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
I received my pneumatic tire bead tool today. Looks well made. I put 100PSI in it a few times and played around with it. A length of PVC could make a nice potato cannon......
I welded a handle on an old small floor jack to keep in the tool box. Will be much easier to use than the factory jack in case of a flat.
It had been out in my barn for close to 20 years. I tested it and it lifts the truck fine.
My left rear tire was slack this morning. I found a nail it it. Must have picked it up yesterday when I was driving around on the ice. Plugged it.
I hope to start tank swap this weekend. Gonna be 11 deg here in the morning and 3 deg Fri morning but back to 38 Saturday.
  #83
Old 02-18-2015, 05:02 PM
Iversen-fords
Like I said I'm not proud of this still. The bumper was busted up already and got sacrificed also.....
  #84
Old 02-19-2015, 02:18 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
We have a 25 year old John Deere too.
  #85
Old 02-19-2015, 07:50 AM
ponykilr's Avatar
ponykilr
ponykilr is offline
^nice
That is clean man.
I plan to take my deck to the guy who blasted my wheels and have it blasted and painted. He is a JD enthusiast and has restored a few. He has the right paint and can do it quicker and better than I can. It has some missing paint and surface rust, need to nip it in the bud.
  #86
Old 02-19-2015, 08:30 AM
im2tall33's Avatar
im2tall33
im2tall33 is offline
I love the light bar you bent up, are you planning on putting lights in?
  #87
Old 02-19-2015, 09:20 AM
ponykilr's Avatar
ponykilr
ponykilr is offline
Yeah, I am investigating lights. Quality halogen probably. HID is still $$$$ and LED is $$$$ too.
Old school KC Daylighter 130W last forever, look good and are bright.
Halogens pull a lot of juice so good relay and wiring and maybe a 130A alternator (which was on the list anyway) will be in order. If I could find some reasonable HID off road lamps I would maybe spend more, they put out incredible light and pull a lot less amps.
I plan to do the headlight relay mod too and put some good backup lamps in the rear bumper (cut holes and mount) Seeing is important LOL
Next tubing project is full length sliders. That's why I have not painted the steps that are on Brutus now, I can sell them later better as they are. Those steps are expensive new.
Then maybe a rear glass protector/headache rack in front of the tool box. I need a place to mount my antenna, the double wall roof makes a standard through the roof mount impractical.
The truck is mostly done. All the reliability things are complete, I would drive it anywhere. Lots of little "wants" and projects left but all of that stuff is just icing.
I would say in no particular order:
1-Tach cluster (Steve from FTE meeting me this week to sell me one for cheap, he is a good guy who I hope to get to know better)
2-Install the Bronco tank
3-Lighting
4-HL relay mod
5-130A alternator
6-Saginaw PS pump
7-Tubing projects
8-Front receiver hitch
9-Fix bouncing speedo
10-'87-91 tailgate
11-New stereo and speakers
12-Lockers
13-RSK
And other little things. Will take a while to do it all but that's part of the fun.
  #88
Old 02-19-2015, 09:29 AM
im2tall33's Avatar
im2tall33
Not all leds are expensive. The ones I put on my truck I have right at $100 into them including shipping and I have had zero problems with them and they are bright as can be.
I know you have seen the front lights. All six I bought for $100 on amazon.
  #89
Old 02-19-2015, 10:53 AM
ponykilr's Avatar
ponykilr
ponykilr is offline
Yeah they are bright. LED off road driving lights are $4-500 a set though.
That is what I am doing to my rear bumper, nice job.
  #90
Old 02-19-2015, 11:26 AM
im2tall33's Avatar
im2tall33
If you mean light bars then yes but my lights on the front got just as good of reviews as rigids and at a fraction of the cost. $65 for four.
And thanks I love my reverse lights. The mean side of me wants to wire them up to a toggle switch as well for when people are tailgating me, just flash them real quick lol. But I don't want to cause an accident by blinding them. They are around 3,000 lumens apiece.
I can see up to 400yards clearly with just the front lights.
Quick Reply: ponykilr's '96 F350 Build Thread
