Let's go snowmobiling in Feb!!!!!
#271
on
Evening all! I was actually amazed that my ride home wasn't much longer than normal.
But I've heard some areas are much worse.
We looked at those Voltages and I really liked them, but it was 50k+ for those. To much for me...
Randy, 13' 2" at the high point of the A/C is what I am at, so you likely would be as well.
#275
The only thing that changed was the Class 1 and Class 2 weight ratings. You need to check and make sure you are a 1 or a 2 now. I believe Calss 1 was up to 1000lbs but now is 1200lbs. The local ordinances allow them to be run in the city limits but State law proceeds in the rural areas. Mostly lax around here due to farming. But I thought you could run them on county roads (shoulder).
#283
Thanks Jim!
A Ranger would be nice!
Thanks Randy! That house is as solid as they come. Built better then the houses today I bet. It has been pretty much completely renovated within the last 10 years.
