Power Windows Work Intermittently
Over the last few years my power windows in my '99 Super Duty have started working intermittently. The problem seems to be with both the main controls on the drivers door and the control on the passenger door. Sometimes both of them have problems operating, sometimes just one. Does not make a lot of sense. Could I have bad switches or do I need to check something else?
Any help here would be appreciated!
Thanks!!
Rowland
'99 Ford Super Duty
7.3 Diesel
Dually
Thanks!!
Rowland
'99 Ford Super Duty
7.3 Diesel
Dually
I'm Having the Same Problem!, Also thought it was in the main switch. I popped the panel off checked the wires and all seemed good. Caught it when it quit working and popped panel off again and wiggled the wires and buggered around with the switches and nothing.
Next day I started up and they worked just fine??
wonder if its how it gets its power when you turn the key?
its got me buffaloed.
2003 F-250 5.4L
ext Cab
206,000 miles
2003 F-250 5.4L
ext Cab
206,000 miles
I had the same problem. It was a wire in the black boot between the driver door and the cab that was broken. Sometimes it would touch and make contact and sometimes it would come apart. Cut the boot open, found the wire, fixed it and sealed the boot back up. Problem solved.
The wires in the boot fatigue from getting worked each time the door is moved. Thats the first place I usually check for this intermittent problem.Then go at the door switches then to the motor and its leads and most importantly the grounds. Try moving the door around when actuating the switch see if that induces the fault.
My solution
The intermittent problem showed up on the drivers door of my '97 Mustang Cobra. It only happened when I parked in the sun with the windows rolled up. Now whenever it's sunny I roll down the windows a few inches so heat doesn't build up in the interior, and the door surface is not super hot to the touch. Problem solved.
Power Window Problem
Seems like my problem increases when the weather is somewhat cold. I will check the wiring in the boot and if good the motors. The main switch looked good. I pulled it out then apart and checked and cleaned all the contact points. WIll let you all know what I find so others can learn from it.
You must live in an honest neighborhood lol :-)
For some reason I'm not getting my notifications when people respond to the posts I've commented on???
If you were asking me about the harness replacement I didn't do it my self, my mechanic did it but I see the old harness and it looked straight forward...hope this helps.
Power Windows
I am still having problems but I tried something yesterday. The window stopped about three inches from the top. Out of frustration I pulled down on the window and in moved about a 1/4 inch. Then it started working again. This makes me wonder if there is a dead spot in the motor.
Any thoughts?
Any thoughts?
