1978 - 1996 Big Bronco
PROBLEM SOLVED: 1995 5.8L Bronco stumbles/misses/bucks when accelerating, under load or climbing
  #31
Old 04-10-2015, 11:27 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Originally Posted by Tim Hodgson
powerstroke72: Thank you! Perfect! (and even if it wasn't I don't mess with people who have avatars like yours...)
Glad to do it. If you need anything else, just give me a shout.
And yeah, I really need to think about changing to a less demented clown.
  #32
Old 04-16-2015, 01:40 PM
Black Ford XLT's Avatar
Black Ford XLT
Black Ford XLT is offline
Tim , FYI I get this also and have narrowed it down to the fuel , my Bronco sits a good bit and the humidity here in the south along with ethanol multiple this problem . Years ago went through everything tps , etc etc etc reading codes etc . Fill it up with non ethanol No problem .
  #33
Old 04-16-2015, 09:58 PM
Tim Hodgson's Avatar
Tim Hodgson
Tim Hodgson is offline
Hey guys, just an update. The cross-firing was between the #8 and #7 wires. I will post a picture of the shiny spots where they were touching and which I would think was cleaned by the arcing.
Hauled a load of firewood in my 1950's Dodge half tone pickup bed trailer up US Hwy 50 today from Sacto to Tahoe area today and no missing. Not once. Not one miss since putting on the new spark plug wires and rerouting them per the wire routing diagram Conanski provided.
Black Ford XLT: I hear you on the fuel. Apologies to Iowa but ethanol is a political scam.
  #34
Old 04-17-2015, 12:46 AM
Bubba Jones's Avatar
Bubba Jones
Bubba Jones is offline
I'm glad you got the stumbling taken care of! I probably need to check my wire routing too. I get pretty lazy when I change wires and have them cross sometimes.
I just fixed an exhaust leak I developed finally when ended up being a section of the EGR tube I "fixed" leaking again.
When I replaced my cylinder heads, my EGR tube line cracked, so cut out that section and I put high temp silicon heater hose over the gap. It worked for a few years! However I started getting pinging the leak was so bad and I finally realized it was from that fix! No more pinging for me.
Anyways, I'll get back to you with the A/C filling stuff too, just let me know if you are getting close to getting around to doing that. I've gotten much busier in school recently with my senior design work and stuff but things will settle down in not too long.
Tim Hodgson
23
12-13-2016 06:21 AM
blue&white
08-08-2013 06:23 PM
cougar_1987
09-01-2009 08:46 PM
majn
Bronco II
03-07-2004 09:35 PM
captntim
02-22-2004 09:46 AM
Quick Reply: PROBLEM SOLVED: 1995 5.8L Bronco stumbles/misses/bucks when accelerating, under load or climbing
