Rear. To sway or not to sway
Old 12-14-2014, 06:06 PM
Ikestang's Avatar
Ikestang
Ikestang is offline
Doing a vic swap on my 69 F100. Planing on using the front vic sway bar but should I install a rear as well?
Old 12-14-2014, 06:27 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Only if you're swapping the rear suspension too...
Old 12-14-2014, 06:30 PM
instig8r63's Avatar
instig8r63
instig8r63 is offline
IMO, 1/2 tons are swappy. My truck has 3600# rear springs and doesn't really apply. Less than 3600# springs on a half ton can benefit from front and rear sway bars.
Old 12-15-2014, 09:59 AM
derbydad276's Avatar
derbydad276
derbydad276 is offline
yup ! hit the pic and pull and see if you can find one off a later f150 or buy an after market
Old 12-15-2014, 10:27 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
I have a front sway bar from a '78 F-250 CS to put on my '69 F-100.
I'm trying to find a Dentside rear sway bar from an F-150 pickup or an F-150 Bronco, for a 9-inch rear end. I know the rear frame rails are 4" wider (2" per side) but, I think I could make it work.
The Dentside/Bronco rear sway bar looks like this.
Old 12-15-2014, 09:38 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
sway bar
Which ever Ford truck sway bar you get will probably have to be mounted under the rear housing to clear the shocks and make up some links.
I have one from a 250 Camper Special and that was the only way it would fit. Good luck
Bruinzfan
05-09-2015 09:35 AM
79Supercab
02-11-2015 04:14 PM
tworock
Aerostar
63
12-18-2005 08:03 AM
funkoptimus
04-08-2005 03:50 PM
Quick Reply: Rear. To sway or not to sway
