Jolly Green Giant...2015 F-350 KR DRW
#602
Received 4,022 Likes
on
Safe trip home !!
#603
on
DieselSite Fuel Filter.......
Installed the DieselSite Aux fuel filter/water separator.........
Easy install
This uninstalled from the 2011 F-350....and Installed on Jolly Green.
Easy install
#604
Received 5,172 Likes
on
Good for you Roy, I'm really glad you saved that filter, good on you man.....
(almost forgot the icon)
#605
on
#608
on
Hey Roy, when you got the truck from the dealer the hubs were locked right,
after you unlocked them, how much did the fuel mileage improve ?????
#610
on
Fuel mileage went up about 2 mpg........
#611
on
There is a sensor on the unit. It is like the sensor on the air filter. When the fuel flow is restricted enough to show on the sensor then the filters get changed. I don't know how long that takes.
#612
on
#613
It's bound to depend on the fuel quality Roy. I have 14,000 on mine and still no movement of the gauge and nothing in either cup - water or sediment.
#614
Well that's good news. I've only seen one instance about ten years ago where fuel filters really ran into bad fuel. A fuel filter that's not needed is much better than fuel filters that are constantly taxed with bad fuel.
Sent from my BlackBerry Passport using IB AutoGroup
#615
The nice thing about these is you can see into the bowls and don't even have to crawl under the truck to check them. A few miles after a fuel stop, a quick glance under the driver's door will tell you pretty much what you need to know.
