Jolly Green Giant...2015 F-350 KR DRW
#1637
Received 4,515 Likes
on
I am pleased that it tested OK.......
This is going to work well for the Electric Fridge.....
#1639
on
I do not know yet...
While traveling.....the truck is charging the Battery bank in the 5th wheel.
Once purely on the Battery......???
#1640
Yeah, was wondering about boondocking. May have to stick with the propane for longer trips, or get a really large solar charger.
#1641
on
#1643
on
That is what bald heads are for.............................
#1646
Started work this evening on the Pure Sine Wave (PSW) Inverter install.
Decided to use quality AC IN and AC OUT connectors. These has to be wired up to the unit.
Then Test it. Will it run the Apartment size Electric Fridge..??
It is a Switching Inverter......meaning, it has an AC IN connection. When there is Shore Power, the load runs off of the Shore Power....not the Batteries. When there is No Shope Power, the Inverter pulls from the Batteries and provides Pure AC power to the load.
(pics removed)
It ran the fridge without any issues........
Battery cables....RED
The lower AC connector.....AC IN
The upper AC Connector.....AC OUT
(pics removed)
#1647
on
1200 Watt Pure Sine Power Inverter
#1648
on
TPMS Install
Installed the TPMS system on Jolly Green today.....
Power is supplied UpFitter Switch #3.
Front ......Port side
Rear.....Port Side
Notice, power wire comes from behind the dash.
Adjustable mount.
Rear.....Port Side
Adjustable mount.
