clifford is getting there now.
#1396
With those numbers, I don't see any way to blame the pump or IPR. A worn IPR will make it romp if it sticks, or make it idle unevenly, but I don't see an IPR producing an idle that sounds like a miss. What most of these do when they warm up is to vary speed just slightly when they're idling hot. The idle speed just wanders a little. Either that or you get an idle that sounds like it has a cam in it and it just lopes a little. At least that's what I have seen most commonly.
#1397
#1399
#1400
I don't have an hpx. From my previous reading joey suggests not having a need with his pump.
The romp is only a hot start issue so far.
Jim is thinking this is a big injector vs..tuning issue possibly.imI'm going to do a cct and buzz test and see if either gives a specific injector...then pull that cover if I can lock that down...otherwise maybe an IPR for good measure and hope live tining helps.
Also I'm going to get the power struck tunes on and see if they idle different or better...this is uncharted territory here..am I missing something?
#1401
#1402
Going to do the tunes tonight and got the solus from my lil buddy.we will get some answers tonight!
Also after a discussion with jim and some history of how these ran....I prob have no actual issue but more a tuning and personality issue.
Wish me luck.
#1405
The tunes made a little difference.at first I was very hopeful. As soon as it got hot here come the missing. Power struck...so far no power! Couldn't even see 20. Just sputtered as soon as it tried to go.
I was going to drive it tomorrow but not sure now.
The scanner that I borrowed is ruined.they never used it after I left.batteries corroded inside and it won't come on.I give up.
#1408
Power sun struck out! What a joke
As soon as boost came on it fluttered and lost power...what a turd.flipped it back to Andrews tunes and hold onto your hat!!! And not on the highest tune. That fella brings the powa
After driving it to work the power struck tunes drive nice and idle is good enough to use the truck.IPR ordering tonight.
#1410
Problem with that Phil, is he isn't taking a chip out of a stock truck and returning it to stock. The tuning NEEDS to be there to make it run properly.
