No heat in cab
  #46
Old 11-23-2014, 07:19 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
In 84 or 85 Ford changed to a bottle with the hose coming in from the bottom. They will keep the system completely full better, in my experience, than the one with the hose coming in from the top. That's why I use the later ones on my 81's.
  #47
Old 11-23-2014, 08:18 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I would rather it suck coolant from the top, because the bottom of the overflow container can accumulate crap.
Makes me wonder what the PSI rating of the radiator cap is; if it's letting loose too early, the system won't build up pressure like it's supposed to.
  #48
Old 11-23-2014, 08:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
What's a normal cap rated at?
13 psi?
  #49
Old 11-23-2014, 08:28 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
It's either 13 or 16 but I forget for certain.... IIRC most Fords are all the same but I forget what that rating is; a shop manual should have it, maybe the owner's manual, or just look online at a parts place and see if you can find it described somewhere.
  #50
Old 11-23-2014, 08:56 PM
FordPUMan's Avatar
FordPUMan
FordPUMan is offline
The 84 shop manual I have says 13 psi.
  #51
Old 11-23-2014, 09:06 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Yep, mine are 13 psi. And, btw, I don't put crap in my overflow tank. Nor my heating system. So if it is gathering there maybe it is time to clean it?
Seriously though, I do find the ones that suck out of the bottom to work much better. I like to keep the cooling system completely full, and the bottom-draw ones do that better IMHO.
bobs 80 f250
03-08-2019 09:26 PM
86BroncoGuy
01-27-2008 08:35 PM
hood
04-21-2007 08:52 PM
Baggins
Aerostar
16
10-03-2005 09:13 AM
77'F-150Mudder
17
12-07-2003 02:18 AM
Quick Reply: No heat in cab
