Hey all. I have an 88 F150 302efi. I bought the truck a month or two ago and finally had some time to do some work on it. So I just finished a Full Tune up but have come across a strange issue. I don't have a Fuel Filter on this truck. I've looked along the Frame Rail and all the nooks and crannies around the area. Anyone have any suggestions? Im stumped...
Fuel filter on that should be after the high pressure fuel pump on the frame rail, near the front of the cab.
There *might* also be one in the fuel reservoir... I have not seen one with a filter in it but I have heard of this being the case sometimes. Whether there is or not, that would only be a secondary filter, the main one should be where I mentioned above.
