AC Bracket for a 1967 F100 300 engine underdash unit
#31
I'm not sure if this is a photo of the end result in the installation or, if the guy went on to install BOTH belts on the compressor (?).
https://www.ford-trucks.com/forums/a...1&d=1344174342
If it's the finished product, I don't understand why the compressor would have been mounted that far forward, when the front pulley groove could have been used and the compressor wouldn't have needed to be placed that far forward (?).
Do you have a single groove alternator pulley or a 2-groove pulley?
What is the V-groove width of your compressor pulley? (Is it for 3/8" or for 1/2" wide belts?).
The basic component part number for the cast iron portion of my A/C bracket is 2882. I'm not certain what the number for the compressor mounting bracket is, at the top of this cast bracket.
The following diagram lists the 2882 bracket but not the bracket that mounts to the 2882 component --this is a power steering pump/bracket diagram. You would need to look at the A/C compressor/bracket diagram to get that part number.
#32
#34
Yepper. And I said this on #16.
Also look at Bill's belt route pics in post #14.
You'll need a 3 sheave crank pulley,idler pulley and it's bracketry,a belt,nuts,bolts,etc. Note how the inner crank pulley sheave (same position as the one you have now) and the outer one for the A/C are different diameters. So you current alternator belt and the A/C belt will be running at different speeds. This is why you'll need an idler pulley for the A/C in place of running both belts on the water pump. You would be far better off finding a donor vehicle in a JY and taking everything off it. This stuff will all match. And you'll have an application for a new belt. <!-- / message -->
<!-- sig --> __________________
#35
Even with using Ford parts, I ran into a few snags but, it wasn't anything that I couldn't come up with a fairly easy solution to remedy it.
These are just things you run into in putting components from one vehicle on another. If you're sourcing the components from some other Ford make/model, get EVERYTHING associated to it. It'll make your life easier when you go to put the parts on your vehicle.
#36
#37
http://fordification.com/tech/images...ts-engcomp.jpg
Finding one may be a different story, along with idlers, brackets, and bolts.
#38
I've never seen a 240/300 with an add-on pulley bolted to the harmonic balancer but in the diagram below, it looks like there may have been one. (See #6A312).
#39
I have seen a thread where Number Dummy commented on the outer accessory pulley. Thanks for bringing up the v-grove belt size. The belt size on the compressor may be a 1/2 inch and the 2 pulleys that I have may fit 3/8 belt. I have to go to where the truck is. If this is the case, I am going to have to look for an outer pulley, I suspect, that fits a 1/2 belt. I wonder if this is going to complicate things even further. Any thoughts?
My truck came from the factory with no engine accessories. It had a single groove water pump pulley, a 2-groove crank pulley and a single groove alternator pulley.
The 3-groove water pump pulley I robbed, from the '82 300, has 3/8" grooves on the middle and rear most grooves and a 1/2" groove on the forward most groove. The new crank pulley I bought is configured the same.
My '82 C2 power steering pump pulley has a 3/8" groove but, I moved the PS pump forward to line up with the forward most (1/2") grooves of the water pump and crank pulleys. This just means the 3/8" PS belt rides deeper in the grooves on them.
#40
It looks like your water pump pulley has 3-grooves (?). It looks like the forward most groove is much smaller in diameter than the middle and rear grooves. Was this water pump pulley on the truck when you bought it or, did you add it?
In looking at the photo that I posted, it appears that the forward most "water pump" pulley may be wider and certainly smaller than the other 2.
The Compressor that I got on Ebay is a 4510/ 6664 SANDEN STYLE 5H14 O RING COMPRESSOR, DOUBLE V BELT PULLEY. Will I be able to run a 3/8 belt on this?
I probably should have had a better understanding of what I needed, what I was buying. At this time, I feel like I have a better understanding of what it takes to complete the job now, thanks to you guys on this site, but still feel I have a lot to learn.
#41
As far as the casting numbers on the engine, water pump, and manifold, all were c6AE numbers. Would this be unusual for a 67 truck (i am assuming that the C6 represents a 1966 block). I did not see a part number or casting number on the harmonic ballancer.
#43
This A/C bezel is not genuine Ford, nor was it used in 1967. This bezel is somewhat similar to the type of dealer installed deluxe A/C used 1968/72.
1967 Ford dealer installed A/C used the same chrome A/C bezel as: 1963/65 Fairlane, 1963/66 Falcon, 1965/66 Mustang & F100/250.
C7AZ-2882-A .. 240/300 I-6 Compressor Mounting Bracket / Obsolete
1965/66 F100/250 & 1967 F100/350 with dealer installed A/C / 1965/67 Galaxie/LTD 240 I-6 w/dealer installed A/C / 1968/69 F100/350 with factory installed integral A/C (combined w/the heater).
Left (upper): 1968/72 Deluxe dealer installed A/C bezel...extends all the way from the left to the right side under the dash.
Right (upper): 1968/72 Economy dealer installed A/C bezel.
Left (lower): 1968/72 F100/350 240/300 I-6 engine compartment dealer installed A/C "mount and drive" parts.
Right (lower): 1967 Galaxie/LTD 240 I-6 engine compartment dealer installed A/C "mount and drive" parts.
#44
In looking at some previous posts, i see that Bill previously mentioned part number C7AZ-6A312-C. I was able to locate one and hopefully this will fit my application. Any thoughts? I was advised that the bolt was an 18 X 2 but did not know if it was metric or standard. Anyone have any idea what Ford used back in 1967?
#45
In regards to the "18 x 2," that is an incomplete bolt descriptor. The best sense I can make out of that is the person was referencing a 5/16"-18 bolt by 2" long. However, that's the wrong size for the (3) threaded holes in your harmonic balancer.
The (3) threaded holes in your harmonic balancer are tapped for 3/8"-16 bolts (3/8" diameter, 16 threads per inch). I'm uncertain what the correct bolt length is for it though.
The holes in the balancer are not blind holes (don't have a bottom to them). They are through holes. If the bolt lengths are too long, the threaded ends will protrude out the back and get into the timing gear cover (crunch! crunch!! ....unt das ist no goot).
