cab gutter seam ?
Old 10-31-2014, 08:10 AM
baverwolf's Avatar
baverwolf
baverwolf is offline
cab gutter seam ?
Repainting my 86 F150 and noticed there is a seam where the cab gutter "I guess that's what it is called" meets the cab and there is remnants of some kind of putty or caulk. Most of it is gone. What should I replace it with?
Thanks!
Ben
Old 10-31-2014, 08:27 AM
reamer's Avatar
reamer
reamer is offline
Seam sealer. DO NOT use any type of silicone. Silicone actually corrodes steel and you will not have any paint adhesion where silicone touches. ( even silicone on your fingertips that touch a door panel will not hold paint)!
Old 10-31-2014, 10:20 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,783 Likes on 1,440 Posts
Make sure you also redo the same seam as it goes across to the top back corners on the cab. This is were it likes to leak and it rusts out your cab corners.
Old 10-31-2014, 06:56 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
Seam sealer, rip out all of the old stuff you can. I did this when I repainted the top of my cab.
Old 11-02-2014, 04:56 AM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
Does seam sealer also act to provide strength to hold the two mating surfaces together, or is it just to level and seal a weld under it?
Put another way. if the seam sealer is cracked now, does that mean there might be a weld under it that is cracked, or is replacing the seam sealer the entire fix?
Old 11-02-2014, 06:16 AM
Franklin2's Avatar
Franklin2
The seams are spotwelded, the sealer makes it watertight. Like all other seals and sealers, the seam sealer gets old and hardens, and then cracks.
jniolon
17
01-15-2022 08:15 AM
Thisguy65
05-22-2017 09:26 AM
birdman1
19
09-11-2008 12:02 PM
bigbubba87
Paint & Bodywork
12-08-2006 06:43 PM
samwe
09-29-2005 07:26 PM
Quick Reply: cab gutter seam ?
