Center tank fuel pump keeps failing - 1988 F250 460
Old 10-01-2014, 10:01 PM
gcgaudette's Avatar
gcgaudette
gcgaudette is offline
Hi folks,
I'm writing this for my Dad, who is 76 years old and not an internet user. He's been a Ford F250 owner / DIY mechanic since he was a young man, but he can't figure out what's going on with repeated center tank (in-tank) fuel pump failures in his 1988 truck -- it keeps failing after a few thousand miles / few months or year or so. I think he said he's been through 8 of them in 9 years, and he barely drives, maybe 5 or 10,000 miles a year. Fuel filter is not very old, likewise "fuel module" (? I'm not mechanically experienced). He gets the replacement on warranty but what a hassle.
If this sounds familiar and you have an idea what the cause might be, I know he'd appreciate it.
Thanks,
George
Old 10-01-2014, 11:27 PM
TobaccoBarn460's Avatar
TobaccoBarn460
TobaccoBarn460 is offline
I've heard some stories about substandad quality pumps but that would be some kind of record.
Is it possible , now that your doing internet searchs for your Dad, to call the techline for the mfg. of the pump, and let them weigh in with their opinion?
You would think they'd have an interest in a situation like this.
Old 10-02-2014, 09:24 AM
gcgaudette's Avatar
gcgaudette
Thanks TobaccoBarn460, good idea, I'll do that.
Old 10-02-2014, 09:41 PM
F350 1990's Avatar
F350 1990
F350 1990 is offline
The vast majority of replacement pumps out there (e.g Airtex, Delphi, etc) are CHINESE, MEXICAN JUNK , substandard and fail frequently --- many infant mortalities along with other early failures caused by clogged/partially clogged fuel filters, contaminated pump strainers, old harness/dirty connector causing high impedance forcing the pump to work harder, and "upstream" problems under the hood impeding fuel flow.......
I'd start with the peripheral items --- clean up the harness/connector, new fuel filter, new strainer.......
Old 10-03-2014, 03:09 AM
tempest411's Avatar
tempest411
tempest411 is offline
I second the opinion on fuel pumps. In particular, if you do a search on the Airtex brand, there's a LOT of complaints about them, which is odd since they are so widely available. Motorcraft PFS141 shows available from Rock Auto. The cost is considerably more than the aftermarket brands, but failing another component being at fault, you get what you pay for...
All aftermarket parts really should go through a certification process to insure that nothing on the market is below the standard of an OEM part. There's a LOT of garbage on the shelves at you neighborhood auto parts stores.
kdbenton
09-16-2013 11:02 AM
73 fourxfour
12-27-2010 01:35 PM
tinman52
1999 to 2016 Super Duty
10-19-2010 11:13 AM
lentz321
03-17-2003 05:53 PM
Quick Reply: Center tank fuel pump keeps failing - 1988 F250 460
