4 speed conversion
Old Sep 7, 2014 | 11:12 AM
72explorer's Avatar
72explorer
No maximum I pull is 2500- 3000
Old Sep 7, 2014 | 11:14 AM
351Cleveland C4's Avatar
351Cleveland C4
You should be fine then, it will just take a bit more throttle to get everything going. I have towed 4,000lbs before without trailer brakes, and I would say the max safe towing limit on these f100s is around 6,000 with trailer brakes.
Also, beware of your speedometer. Depending on what drive gear on your speedo cable, you may not be able to correct it for the higher gears.
Old Sep 7, 2014 | 11:18 AM
72explorer's Avatar
72explorer
How many rpm am I spinning with the 3:23 or how do I figure it
Old Sep 7, 2014 | 11:25 AM
351Cleveland C4
The way to figure it is relatively easy with a calculator.
MPH X 5,280 gives you feet per hour
Feet per hour X 12 is inches per hour
Inches per hour / 60 is inches per minute
Inches per minute / circumference of your tire size. (In your case 94"). This gives you your wheel RPM.
Wheel RPM x gear ratio= drive shaft RPM
Driveshaft rpm is engine rpm in your case, because you have a manual trans with a 1:1 gear ratio.
Understand?
You can figure other trans gears by multiplying for lower gears, and dividing for higher gears. If you had an auto, TC slippage would also come into play.
Old Sep 7, 2014 | 11:33 AM
351Cleveland C4
3.23@ 65 = 2,358rpm
Old Sep 7, 2014 | 11:35 AM
72explorer's Avatar
72explorer
Thanks so changing to a 3.00 I'll gain a mpg or 2 hopefully
Old Sep 7, 2014 | 11:38 AM
351Cleveland C4
Possibly. But it will be a more comfortable rpm. Honestly, if you never drive over 70 or don't drive often. I would probably stick with what ya got.
Old Sep 7, 2014 | 11:44 AM
72explorer's Avatar
72explorer
Well I drive it quite a bit not much over 70 and I like the bottom end I have so unless I find a nice 5 speed I guess I'll let the 3 speed stay
Old Sep 7, 2014 | 11:50 AM
351Cleveland C4
You can do like HIO Silver has and get a TKO-500 5spd OD tranny. Then you can switch axle gears down to 30 or so and have even more fun.
Or switch to an automatic AOD
Old Sep 7, 2014 | 11:52 AM
72explorer's Avatar
72explorer
Where would I find such a tranny? It's a project truck so I'm open to ideas!
Old Sep 7, 2014 | 11:53 AM
351Cleveland C4
AOD comes from Craigslist or junkyard
The 5speed I'm not sure. I've never looked for one.
Old Sep 7, 2014 | 11:59 AM
HIO Silver's Avatar
HIO Silver
Talk to Bruce at Modern Driveline.
A 3.50 rear gear with a 0.68 fifth gear with 28-inch tall tires puts the RPM at 2000 RPM at 70 MPH... Perfect for a torquey FE.
Old Sep 7, 2014 | 12:02 PM
  #28
72explorer's Avatar
72explorer
Where'd u get your tko hio?
Old Sep 7, 2014 | 12:04 PM
  #29
351Cleveland C4
That's about what I'm going for too. .67 4th gear with 4:11 rear gears on 31" tires will be 2100 at 70.
Old Sep 7, 2014 | 01:20 PM
  #30
derbydad276's Avatar
derbydad276
forget the top loader go with a T5 from a mustang GT
