1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6 inch lift and 35's
Old 08-27-2014, 08:25 PM
Mike189677's Avatar
Mike189677
Mike189677 is offline
[QUOTE=tjcprop;14615915]
Originally Posted by Mike189677
here's some 6 and 35's pics thought I had some more but can't find them these are all the same truck I think the wide wheels make it tires are 35x13.50's
Your 35s look small. Is this due to less rubber because of larger rims? The gap in the wheel wells look huge.
It's not my truck I don't really like the big wheels those are 20 x either 12 or 14 wide can't remember which but the wide wheels are probably stretching out the tire a little but I do like the the stance if the tires were any taller they would rub the fender and bumper with the wide wheels and it was a picture of 6 and 35s like the op was asking for but thanks for your opinion.
  #32
Old 08-27-2014, 08:28 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
[QUOTE=Mike189677;14619184]
Originally Posted by tjcprop
It's not my truck I don't really like the big wheels those are 20 x either 12 or 14 wide can't remember which but I do like the the stance if the tires were any taller they would rub the fender and bumper with the wide wheels and it was a picture of 6 and 35s like the op was asking for but thanks for your opinion.
It was a question more than an option but thank you.
  #33
Old 08-27-2014, 08:34 PM
3/4ton4X4's Avatar
3/4ton4X4
3/4ton4X4 is offline
I actually dont think that the 35's look to small in your pictures any way. and the stance is great. But for my taste there is to much rim but man i wish mud grapplers came in 35x13.5 or 14.5
  #34
Old 08-27-2014, 08:41 PM
3/4ton4X4's Avatar
3/4ton4X4
Both trucks are pure work trucks used for hauling and plowing. What is wrong with keeping company trucks looking like new, clean and presenting a good image for my business? Both trucks are not factory and have several custom features to make these work strong.
I am sure your truck will not see the frigid nasty weather mine will and be forced to work 20+hrs non stop.
I totally agree with keeping a clean truck and especially one as nice and as new as yours is. I just have a totally different view on the reason to lift a truck. This could be a long debate. But some people want to actually use their over sized tires and lift for off road and some people just want to use it for show and i can respect both perspectives. And btw My truck plowed snow here in Michigan for 2 years before i lifted it and the first 5 it was a strictly work truck for a large construction company out of grand rapids. Im sorry if i offended you by saying lifted trucks should be used for offroading and your superduty looks great but its just not my style, if i ever have a work truck it would be a base model truck with maybe a tuner to help with economy and towing.
  #35
Old 08-27-2014, 08:49 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
No offence taken. Thank you for the apology. In my area I am known for my lifted clean work trucks and have gained business with this advertising. My mechanic yells at me for plowing with lifted trucks but has extended the bump stops and more to keep trucks working.
  #36
Old 08-27-2014, 08:58 PM
3/4ton4X4's Avatar
3/4ton4X4
Thats funny because i was trying to talk my boss into buying me a plow to plow our work lot and make him some money on the side but he said that i shouldnt plow with a lifted truck. I guess you are proof other wise hahaha.
  #37
Old 08-27-2014, 10:49 PM
Prof_Bob's Avatar
Prof_Bob
Prof_Bob is offline
Sorry for my ignorance here, guys, but why shouldn't you plow with a lifted truck...? Does it pull the front end down too much, or is it a balance issue...or...?
Thanks much for any info you can share.
  #38
Old 08-28-2014, 06:14 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
Plowing with a slightly lifted 250 vs 150 is better because the 250 has a heavier duty front suspension. Yes the plow weight pulls the front suspension down. Pulls it down more if the improper plow is used. Also the act of pushing snow as it gets heavier as the plow blade gathers more is hard on the suspension, diff, gears and trany. Is it more true if a lifted 150 with larger heavy tires are added to a truck with factory non suitable gears. Plus the ability to remove snow throwers out of the bed of a lifted truck gets employees b!tching.
My 150 has been built for plowing with a lift. 4.88 gears, 9.75 diff, new heavier duty trans, extended bump stops and the proper plow Western Suburbanite weighting in at 340lbs. Great for driveways.
  #39
Old 08-28-2014, 06:21 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
Improper plow, Boss Standard Duty with wings, 1100lbs. This is a lifted suspension killer.
  #40
Old 08-28-2014, 02:31 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
thats a pretty light duty plow anyways, your drop brackets for ifs lift should be fine if they got welded up togeather after being bolted on. otherwise it will be a snap crackle pop fest under that truck.
  #41
Old 08-28-2014, 03:45 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
As i typed early, this is the incorrect plow for this lifted truck. Using the proper plow which is far lighter and doesn't stress the suspension much.
  #42
Old 08-29-2014, 11:41 AM
Prof_Bob's Avatar
Prof_Bob
Prof_Bob is offline
Thanks for the explanation...! Very interesting info on the necessary alterations to handle the load, plus the differences between F150 and Superduty capabilities.
Just out of curiosity, do you contract with the city for road plowing or work entirely privately for driveways and the like?
Thanks again for the insight.
  #43
Old 08-29-2014, 09:27 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
Prof_Bob my business is entirely private contracts. I do not even touch sub-contract work. So we plow driveways and smaller parking lots.
  #44
Old 08-30-2014, 01:50 PM
3/4ton4X4's Avatar
3/4ton4X4
could Any of you guys with 35's give me some measurments please? like tire to fender clearence front and rear. And telll me what lift you have also. Thanks
  #45
Old 08-31-2014, 01:01 AM
Joe Bloomingdale's Avatar
Joe Bloomingdale
Joe Bloomingdale is offline
Pretty sure I'm late to the party but here is what it looked like with a 6.5" lift and 35" swampers.
Quick Reply: 6 inch lift and 35's
