Vin decoding
Old Jul 12, 2003 | 05:58 PM
superbee's Avatar
superbee
Vin decoding
HI, i found a vin on my truck that i need help decoding.
F75WU372784*
156 G F755 81A
J H7E 25000 173 3600 53
Old Jul 12, 2003 | 06:53 PM
captcarstop's Avatar
captcarstop
Vin decoding
vin decoder Should give you what your looking for. If not, keep asking and you will find your answer sooner or later.
Ron
Old Jul 13, 2003 | 11:11 AM
superbee's Avatar
superbee
Vin decoding
Nope, couldnt find my stuff on it, any other ideas?
Old Jul 14, 2003 | 11:27 AM
Mike G's Avatar
Mike G
Vin decoding
How about some indication as to what the truck looks like and where you found the VIN Stamp. By all accounts, it seems to be a larger truck, maybe even a dump truck... Possibly built in Jan of 1963.
--MG
Old Jul 14, 2003 | 12:13 PM
superbee's Avatar
superbee
Vin decoding
yeah, its got a large tilting flatbed on it, its a 2 maybey 2 1/2 ton with 10 tires, 3 axles, (only one drive) its an F-750.
It had the vin on the drivers side door
Old Jul 15, 2003 | 12:27 PM
Mike G's Avatar
Mike G
Vin decoding
Well now that explaines the F75 at the beginning of your VIN...
Sorry I cannot add more info for you, what would you need? Maybe someone can chime in with the "W" code engine displacement for the 1963 big trucks, but with 173 hp, my guess would be in the range of a 361ci.
Happy Hunting! --MG
Old Jul 15, 2003 | 12:29 PM
superbee's Avatar
superbee
Vin decoding
i gave up on it, but thanks for the info. Unless anyone figures out what engine it is, if its one thats worth somthing, ill take it out.
Old Jul 16, 2003 | 12:06 PM
Mike G's Avatar
Mike G
Vin decoding
Well.... What would be under the hood? Is there a V8 or I6? If is is a V8, are plugs angled in like \\ // and the exhaust manifolds like ram-horns? This would mean a FT (as opposed to FE). A little more info, maybe we can help.
--MG
Old Nov 18, 2003 | 08:35 PM
superbee's Avatar
superbee
well i just got courious about it, it was a v8, it had straight spark plugs i remember.
Old Nov 20, 2003 | 03:27 PM
banjopicker66's Avatar
banjopicker66
Superbee: I would have responded earlier, but I have been traveling the last 3 weeks. Here is the decoding:
F75 - F 750 Series
W - 8 cyl gas engine 4 bbl 332 CID (NOT 352!)
U - Louisville, KY plant
372784* January 1963
156 - Wheelbase length
G - Chrome Yellow
F75 - Model
5 Trim Code
81A - Conventional Standard cab
J - Medium Duty Clark 250 V transmission
H7 - Two speed Eaton 6.50 ratio and 8.87 ratio rear axle with 18,500 lb capacity
E - Heavy duty 7,000 lb capacity front axle
25000 - Maximum Gross Vehicle Weight
173 3600 - 173 HP @ 3600 RPM
53 - DSO Kansas City
Old Nov 20, 2003 | 05:02 PM
superbee's Avatar
superbee
Wow, thanks banjopicker66. I bought stuff for a 292, so thats why it wouldnt start. Thanks for the info man.
Old Nov 20, 2003 | 05:32 PM
banjopicker66
Superbee, keep in mind that this info assumes that the warranty plate is original to the truck, and that the engine/trans etc have not been been altered or changed out.
Old Nov 20, 2003 | 07:06 PM
superbee's Avatar
superbee
Yeah, its origional engine but rebuilt. So its a 63'? i thought it was a 66. hmmm
Old Nov 20, 2003 | 07:26 PM
banjopicker66
Superbee: If your numbers on the first line are correct, then yes, it is a '63. What does the * mean in your post? Is it there on the warranty plate?
Old Nov 20, 2003 | 10:25 PM
superbee's Avatar
superbee
i think it was. I might check somtime
