1999 F250 7.3 won't start first try but will the second try
Old 10-12-2014, 01:03 PM
tommyl's Avatar
tommyl
tommyl is offline
What happens if you plug the truck in prior to staring?
Old 10-29-2014, 09:54 PM
rmacinc22's Avatar
rmacinc22
rmacinc22 is offline
1999 F250 7.3 Still not starting on first try
What do you mean by plugging it in? The motor plug or the battery (I've done both)? I just put a new glow plug relay on and it didn't change a thing. Still does the exact same thing EVERY time... Turn the key on, wait till the "wait to start" light goes out then try to start it. It will crank for a short time and act like the batteries are going down but not start. Then I shut the key off and immediately try the same sequence again, only the second time around, it starts like a new truck. New batteries and new glow plug relay, 60,000 miles garage kept. Are there any 7.3 gurus out there that can help?? Not really wanting to take it somewhere and spend a fortune for something I might be able to do myself with a little help.
Thanks!!
Old 10-29-2014, 10:50 PM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
Where are you located?
Old 10-30-2014, 09:03 PM
rmacinc22's Avatar
rmacinc22
Still need help on my 1999 f250 7.3 diesel
Bloomington, Indiana
Old 10-30-2014, 09:31 PM
scotttahoe's Avatar
scotttahoe
Thought maybe if your close by I could put my AE on their but that is a little far from Nevada.
Old 10-30-2014, 10:02 PM
78fordman's Avatar
78fordman
78fordman is offline
What rpms are you seeing on the 1st crank? I know 6.0s have to see min 150.
Old 10-30-2014, 10:35 PM
dtbass409's Avatar
dtbass409
dtbass409 is offline
got close to the same problem and more ?
if i don't plug the motor up on cold nights (40's to 50's) it will not start until it warms up ! Also i've try'd to install two different programs in it, 1st was hypertech, 2nd just today a brand new Edge EVO CTS and once again the truck wouldnt take the program. Any Help would be great !
Old 10-30-2014, 11:28 PM
scotttahoe's Avatar
scotttahoe
Don't know much about the Edge, most here use Dp tuner.
As for your no start, it's probably your GPR (glow plug relay). You need to test it with an ohm meter. In a bind you can jump both large leads for 30 seconds and see if it will start.
Old 11-10-2014, 04:55 PM
dtbass409's Avatar
dtbass409
Thanks Scott, I'll Check that relay for sure. I just thought it was the norm having to plug them up at 50 or below. I've been hotrod'n most my life but Diesel's are fairly new area, but i learning quick though trail and error !
Old 11-10-2014, 11:12 PM
scotttahoe's Avatar
scotttahoe
I know the trail and error one!
I usually don't plug in my truck (as much as I want to) all last winter she fired up after cycling the glow plugs a couple of times she always fired up in 10 degrees no problem.
Old 11-17-2014, 08:02 PM
rmacinc22's Avatar
rmacinc22
1999 F250 7.3 won't start on first try but will the second try
I finally got it going. Never would have dreamed it with the symptoms I was having but it was the starter. I posted on three threads and got some good help and advice. THANKS!!
Old 11-17-2014, 08:42 PM
scotttahoe's Avatar
scotttahoe
good find on the starter, that would be a big one on no start.
  #28
Old 11-18-2014, 07:02 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Good job. Sometimes its the easiest thing that just goes right past our minds.
  #29
Old 11-18-2014, 07:38 AM
tommyl's Avatar
tommyl
tommyl is offline
Where did you get the new starter and how $$?
93_zj
1997 - 2003 F150
01-15-2011 10:04 PM
robbyf250
08-15-2010 09:26 PM
Nels1
Modular V8 (4.6L, 5.4L)
05-09-2010 12:16 AM
sam_1800
03-04-2010 07:01 AM
dakzaag
04-19-2009 12:05 AM
Quick Reply: 1999 F250 7.3 won't start first try but will the second try
