While driving today I hit a large bump going 35 and my truck started to run rough and died. It will start and idle rough and then die when put in gear. I switched to the rear tank and it idled fine and ran in gear. What will cause it to run rough on the front tank and die in gear but run perfectly fine on the second tank?
I am still able to choose between both tanks. It idles normally w the rear tank, but idles poorly on the first tank. If I push the gas pedal on the first tank it stutters and is slow to respond.
