1949 F4 V8 to Mercedes diesel build thread
Old 12-28-2015, 09:37 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
CBeav, Thanks for the reply. The drivelines between the two transmissions and rear axle are not straight. The Brownie is offset to the drivers side about 1 1/2" for PTO shaft clearance and a little lower than the 4 speed. The output yoke of the Brownie is several inches above the pinion yoke on the rear axle. My concern is that the yokes all have to be parallel to one another for the joints to work properly. I have the rear yoke of the 4 speed and the front yoke of the Brownie at 3 degrees so they are parallel but, the pinion is at about 3 3/4 degrees. That gives me about a 3/4 degree difference out of parallel between the rear yoke of the Brownie and the pinion. I am checking the angle with a protractor for a combination square. I think 3/4 degree difference on the rear driveline will be close enough as I'm sure the pinion angle may change slightly with the truck loaded. I hope this made sense.
Thanks again, Mark
  #167
Old 12-29-2015, 02:47 PM
CBeav's Avatar
CBeav
CBeav is offline
*grinning* I just re-read what I typed (came down with a sore tooth Sunday and I've been taking Vicodin until the dentist shows up tomorrow) Apparently my mind was a little fuzzy. ;-) I was trying to be supportive. 3/4 - 1 degree from parallel is acceptable between devices. Minimum of 1 degree offset required to ensure joint life. You've got that covered. Now I'm going to tape my fingers together until I get off the meds. LOL
  #168
Old 12-29-2015, 05:18 PM
49fordv8f4's Avatar
49fordv8f4
Thanks for the reply. I hope you get to feeling better soon. A bad tooth can be really debilitating.
  #169
Old 01-01-2016, 04:36 PM
49fordv8f4's Avatar
49fordv8f4
I have the fuel supply and return lines run. Here are some photos.
This is the fuel return line connected to bulkhead fitting thru the floor of the cab. I will change this hose when I get some more fittings for the Aeroquip braided stainless hose.
This is the return line thru the bottom of the cab floor and connected to another bulkhead fitting thru the frame.
The upper line is the return line and the bulkhead fitting. The lower line is the fuel supply coming from the filter behind the cab.
This is the filter and plumbing.
  #170
Old 01-01-2016, 04:45 PM
49fordv8f4's Avatar
49fordv8f4
Here are some more photos.
This is a fitting block to connect the Aeroquip hose to 5/16" flare hard line. I have to change the hose end when I get some more of them.
This is the supply line (lower) and the return line (upper) clamped to the inside of the frame under the steering box.
This is one of the clamps I made for the lines.
This is the die I used in my hydraulic press to make the clamps.
  #171
Old 01-01-2016, 04:54 PM
49fordv8f4's Avatar
49fordv8f4
One more time.
Here are the lines connected to the filter on the engine.
This is the under side of the bracket in the photo above as the lines come thru the motor mount crossmember. I used 5/16" steel line from a 25' coil to make the lines. The tube straightener worked really well. I still have to paint the rear filter bracket and add hose clamps to the connections on the engine.
Thanks for looking, Mark
  #172
Old 01-01-2016, 06:08 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Very nice work! Your attention to detail is outstanding.
  #173
Old 01-01-2016, 07:37 PM
49fordv8f4's Avatar
49fordv8f4
Thank you Scott, for the kind words.
  #174
Old 01-01-2016, 10:21 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
That looks like a well constructed fuel system. I like the factory quality you put into your work.
  #175
Old 01-02-2016, 04:25 PM
49fordv8f4's Avatar
49fordv8f4
Thank you Fred, My goal is to make everything look like it belongs there.
Thanks again, Mark
  #176
Old 01-30-2016, 07:00 PM
49fordv8f4's Avatar
49fordv8f4
I received my Aeroquip hose ends and fuel hose clamps from Summit this week. I replaced the temporary hose end on one hose and made up a stainless braid hose for the return line inside the cab. I installed all the hose clamps on engine fuel lines. Today I removed the tank, insulated the cab behind it in reinstalled the tank permanently. I tightened all the fuel line fittings and changed the two fuel filters. I put about 2 1/2 gallons of diesel in the tank, bled the rear filter and pumped fuel to the engine with the priming pump. So far no leaks. I'm getting closer to being able to start it.
  #177
Old 02-01-2016, 09:34 PM
49fordv8f4's Avatar
49fordv8f4
ITS ALIVE! I started the diesel tonight for the first time since removing it from my car 3 years ago. I was surprised and pleased how easily and quickly it started. It runs smooth so the flywheel balance is good. The starter is smooth and quiet so the engagement is good there too. The Ford 390 starter has plenty of power to turn the diesel. I'm a happy camper.
  #178
Old 02-01-2016, 09:45 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Congrats! Always a great feeling to hear them run after all that hard work.
  #179
Old 02-01-2016, 09:51 PM
toby tough's Avatar
toby tough
toby tough is offline
IT'S ALIVE reminds me of when I first got my truck to run. Great memories for you and some great work there too.
  #180
Old 02-01-2016, 10:14 PM
Nicholas+'s Avatar
Nicholas+
Nicholas+ is offline
Congrats. Hey, where did you get that die for your fuel clamps?
Quick Reply: 1949 F4 V8 to Mercedes diesel build thread
